ᐅ What to do if IKEA HEMNES furniture wobbles after assembly?
Created on: 17 May 2023 08:24
kuto34
I recently assembled a cabinet from the IKEA Hemnes series. After putting it together, the cabinet wobbles noticeably, especially when pulling on the door or giving it a light tap. The wobbling is more than just a slight sway; it feels generally unstable. I followed the instructions carefully, tightened all the screws, and installed the back panel. Still, the problem persists.
My main question is: What are the possible causes of such wobbling specifically with Hemnes furniture after assembly? And most importantly, what can I do to improve the stability without having to completely disassemble the cabinet? Are there any special tips regarding fasteners, the use of washers, or leveling on the floor (e.g., uneven surface)?
I look forward to your experiences and helpful advice!
todunar
17 May 2023 10:33
Hey, I know that feeling! My Hemnes also wobbled at first, but it settles down! My advice: take your time to carefully check every single connection point. It’s really satisfying when you feel the difference and the wardrobe stands firm like a rock! Remember to also compensate for slight floor unevenness – that helps a lot. You’ve got this!
Joshbe
17 May 2023 11:08
The following steps can help resolve wobbling issues with HEMNES furniture:
- Check and, if necessary, tighten all screws and fasteners
- Inspect the back panel for correct positioning and stability. Often, the back panel is the main element for reinforcement
- Check for floor contact. Unevenness can be compensated for using furniture sliders
- Secure the furniture to the wall, if possible
Another option is to replace or supplement the screws with longer or stronger ones if the existing hardware has any play.
eldubi
17 May 2023 11:21
Check whether the back panel is evenly secured all around. Often, a nail or screw is missing. Sometimes, it also wobbles if the wooden dowels are not properly seated. If the floor is uneven, use washers.
kuto34
18 May 2023 07:55
Nakar33 schrieb:
Did you make sure the metal connectors were fully tightened all the way in? Often they feel tight enough, but turning them an extra quarter turn can add a lot of stability.
Thanks for the tip, I will specifically check that again today. I will also double-check if the back panel is firmly and fully seated – I have the impression that there is a slight gap in one spot, which I had so far considered not to be a problem.
Lilau schrieb:
I had the same issue with a HEMNES cabinet. What helped me was loosening the back panel and securing it again with some small additional nails.
Could you please share more about the type of nails you used? I want to avoid any damage but make it more secure.
I will report back on how these measures work out. Thanks again for the support!
Nakar33
18 May 2023 08:15
kuto34 schrieb:
Thanks for the tip, I will check that again carefully today. I will also double-check that the back panel fits tightly and fully
Good idea! Regarding the nails for the back panel, I recommend small, thin steel nails like those commonly used for furniture back panels, between 15 and 20 mm (0.6 and 0.8 inches) long. At hardware stores, you can find special furniture nails for securing panels. Make sure not to drive the nails too close to the edge to avoid splitting the wood.
If you want, I can also give you some tips on how to gently hammer the nails in using a hammer and a small piece of wood. However, since I don’t know your level of DIY experience, please be careful!
Another option would be to attach a narrow strip on the inside of the back panel with screws, although this is a bit more involved.
Lorukeo
18 May 2023 09:02
Additionally, I would like to point out that material tolerances can sometimes play a role. If the drill holes are not made precisely, dowels or fasteners may not grip properly. This can cause some play, even if the assembly is done correctly.
If instability persists after tightening the screws, pressing the back panel evenly and securing it with extra tape or light adhesive can help. Although this is not a standard solution, it can be very effective in some cases.
I also recommend checking the feet for any damage or deformation. A foot edge that does not sit flat can cause slight wobbling.
