ᐅ Which Ikea PAX wardrobes have the most durable doors?
Created on: 21 Feb 2015 18:43
ALFEOLO
ALFEOLO
21 Feb 2015 18:43
Hello everyone, I am currently planning to expand my wardrobe using the Ikea PAX system. My main question is: Which Ikea PAX wardrobes have the most durable doors, especially in terms of stability and long-term robustness?
I have read that there are different types of doors (for example, folding doors, sliding doors, or classic hinged doors) that vary in materials and construction. It is important to me that the hinges and door design are very sturdy and that the doors do not warp or become loose even after frequent use.
Are there any experiences or recommendations on which doors for the PAX wardrobes are truly the most stable? Maybe also differences between the various door materials (wood, glass, MDF) or depending on the door size? I look forward to any concrete tips or advice that can help in choosing the most durable doors by far.
rotofra
22 Feb 2015 09:17
Hello ALFEOLO,
I’m glad to address your question. The stability of doors on the Ikea PAX wardrobes depends greatly on the type of door and material used.
- Hinged doors with a solid wood or MDF core are generally more stable than flexible folding doors or large glass sliding doors.
- Hinges on hinged doors are solidly constructed, but it’s worth pairing them with Ikea’s reinforced concealed hinges.
- Folding doors save space but are more prone to warping with frequent use.
- Large sliding doors made of glass or lightweight materials look modern but often have issues and tend to develop track problems over time.
A small tip: pay close attention to precise adjustment during installation and consider additional reinforcements if you have particularly wide doors.
Summary: For maximum stability, I lean toward traditional hinged doors with an MDF or wood core, as they warp the least and are very sturdy externally.
lechen
22 Feb 2015 15:34
rotofra schrieb:
For maximum stability, I prefer traditional hinged doors with MDF or solid wood cores
I can confirm that. In terms of mechanical stability alone, hinged doors are the most robust solution. Sliding doors, especially on wide cabinets, tend to be mechanically vulnerable.
If you properly align the door and use the Ikea fittings, they will last long and remain stable.
geneda
23 Feb 2015 11:02
Hello ALFEOLO,
I would like to add that when considering the sturdiest doors for a PAX wardrobe, not only the door material itself is important but also the load and frequency of use play a role.
- If you need frequent access, sturdy hinged doors made of solid materials like MDF are better suited than folding doors, which tend to lose functionality under heavy use.
- Glass fronts look nice but are more delicate if you prioritize robustness and long-term stability.
- Some users report that larger wooden doors cause their hinges to loosen faster, so regular adjustments should be expected.
A tip: If the wardrobe is very wide, it’s worth planning the doors in multiple segments (for example, two narrower doors instead of one large one). This increases the stability of each door and makes installation easier.
If you’re still unsure about the best material and door type, you can also ask specifically for sturdy fittings or look at test assemblies in the IKEA store. This way, you get a better sense of door quality.
