ᐅ Which versions of the Ikea PAX wardrobe system are especially easy to maintain?
Created on: 22 Mar 2020 09:13
Lukazim
I am looking for low-maintenance options within the Ikea PAX wardrobe system. Specifically, I am interested in which of the many different doors and finishes are easy to clean in everyday use and are as resistant as possible to scratches, stains, or moisture.
I have read that, for example, lacquered fronts can scratch easily, and wood-like surfaces might require different care. It would also be helpful to know if there are combinations with glass or mirror fronts that can be kept clean without much effort.
The goal is a low-maintenance wardrobe that is both visually appealing and practical for daily use. Who has experience with the various PAX options and can share advice on materials and cleaning? Thanks in advance!
Gregory
22 Mar 2020 15:07
Here is a brief overview of typical Pax fronts regarding maintenance:
- Melamine coating: water- and scratch-resistant, easy to clean with a damp cloth
- Foil front: somewhat more prone to scratches, avoid using aggressive cleaning agents
- Matte lacquer front: good, as it is less sensitive to fingerprints than high gloss
- High gloss lacquer front: sensitive to scratches and fingerprints, requires regular cleaning
- Real wood / solid wood: demanding maintenance, do not clean with moisture, special oils require time and effort
- Glass fronts: easy to clean, but dust and fingerprints are visible
For most everyday situations, melamine and matte lacquer fronts are the most recommended.
jelite
23 Mar 2020 08:37
I would like to provide a brief guide on how to properly care for PAX fronts, especially the most common types:
1. Melamine/foil fronts
- Wipe with a slightly damp microfiber cloth. Do not use abrasive cleaners.
- For stubborn stains, use dish soap, then wipe thoroughly with clean water.
2. Lacquered fronts (matte and high gloss)
- Use a soft, damp cloth that won’t cause scratches.
- For high gloss, use a special polish designed for furniture surfaces to maintain shine.
- Regularly remove fingerprints to prevent lasting marks.
3. Glass fronts
- Use glass cleaner applied to a soft cloth, not sprayed directly onto the glass.
- Remove dust more frequently as it is highly visible.
4. Solid wood/real wood fronts
- Regularly treat with wood oil or wax.
- Never clean with excessive water, as this can cause the wood to swell.
In summary, melamine-coated and matte lacquered fronts require little effort to maintain. Glass fronts are easy to clean but show dirt more clearly.
DAMALO
23 Mar 2020 10:14
I can understand well that choosing the surface finish for the PAX wardrobe can also be an emotional decision. You want the maintenance to be stress-free and, above all, to work well in everyday life.
However, I have sometimes seen that with a bit of patience and proper care, even more sensitive fronts can stay looking nice for a long time. But that takes time and sometimes a bit of practice.
It’s great that so many helpful tips have already been shared here. I would recommend checking out the PAX wardrobe in the IKEA showroom before buying, and if possible, feeling the surfaces with sample pieces. This is the best way to assess which finish feels most manageable for you personally.
NUGRANT
24 Mar 2020 07:59
Wow, the discussion here is really helpful!
I have a PAX combination with matte lacquered fronts myself and can confirm: fingerprints are hardly visible, and cleaning is really quick.
What I especially like is that you don’t need any special cleaner; a damp cloth is usually enough. Highly recommended for anyone who wants an easy-care yet elegant solution!
Thanks to everyone for the many tips – it really motivates me to make the rest of my furniture low-maintenance as well.
Lukazim
24 Mar 2020 20:33
Gregory schrieb:
For most everyday situations, melamine and matte lacquered fronts are the most recommended.
Thank you for the clear summary, Gregory. That roughly matches my assessment based on the information from the Ikea website and previous user opinions in the forum.
Finally, I’m interested to know if anyone has experience with how melamine-coated fronts hold up over several years. Are there any long-term experiences to rely on, or is matte lacquered PAX generally preferable in terms of maintenance and durability?
Thank you for your time and expertise!
