ᐅ Which Ikea Pax options are the most affordable?
Created on: 21 Dec 2020 18:37
ronman31
ronman31
21 Dec 2020 18:37
I am currently planning to buy a new Ikea Pax wardrobe system and am particularly looking for options that offer the best value for money. It is important to me that the wardrobe is not only affordable initially but also as flexible and expandable as possible, so I can adjust it later if needed.
Which Pax variants—specifically frame and door combinations—would you consider especially cost-effective and recommend? I am especially interested in whether narrower modules or standard widths generally offer more savings, and if you have any tips on how to save money when purchasing or assembling the Pax system overall.
I look forward to your experiences and well-founded advice!
Khalil
21 Dec 2020 19:14
ronman31 schrieb:
Which Pax options, specifically frame and door combinations, would you consider to be especially cost-effective and recommended?
Great that you’re thinking about this! 😊 With Ikea Pax, it’s definitely worth paying attention to the narrower modules, such as 50 cm (20 inches) wide frames, as these are often cheaper than the larger 75 or 100 cm (30 or 40 inches) ones.
More than that: simple, combinable doors without too many extras—like plain white fronts—are usually much more affordable than those with glass inserts or more elaborate designs. Choosing the basic model can really save you money while still offering good style!
Tip: Take advantage of Ikea promotions, which happen fairly often—especially during sales periods, you can get some great deals! Keep an eye out, it’s worth it!
Domau0
22 Dec 2020 07:29
ronman31 schrieb:
Which Pax variants, specifically frame and door combinations, would you consider particularly affordable and recommendable?
To identify the most cost-effective options within the Ikea Pax system, several factors should be taken into account:
- First, the basic frame dimensions: The narrower frames with a width of 50cm (20 inches) are generally cheaper per unit than larger options. However, the price per storage capacity can vary if you buy several smaller modules instead of fewer larger ones.
- Door types: Painted, simple fronts are more affordable than glass or mirrored doors. Sliding doors tend to be more expensive than hinged doors overall—this should be considered when planning your budget.
- Interior fittings: A minimal basic setup with shelves and hanging rails keeps costs low, while specialized solutions like drawer inserts or internal lighting can be avoided at first.
- Assembly and expansion options: You often save money by starting with simple modules and adding standardized extensions later as needed.
Could you also share some details about your room and intended use? That would help provide more precise recommendations, since some variations are not only more affordable but also more space-efficient for certain room situations.
pikin
22 Dec 2020 09:02
Khalil schrieb:
Modular doors without too many extras, meaning rather simple white fronts, are usually much cheaper than those with glass inserts or more elaborate designs.
That is correct. Based on my research and price comparisons at Ikea:
- The cheapest Pax options are frames with a width of 50 cm (20 inches) combined with simple solid doors in white or light wood-look.
- Sliding doors increase the price on average by about 20-30% compared to standard hinged doors.
- A frame without doors or interior fittings is considerably cheaper, which makes sense especially if you plan to use your own solutions or third-party products for the interior.
- In the area of special offers (e.g., discontinued models, clearance items), you occasionally find particularly inexpensive options, but these have limited availability.
In practical terms, the best price-performance ratio is achieved by choosing the standard modules with simple fronts and keeping the interior fittings minimal, at least as a starter solution.
If anyone is looking for a rough price estimate or comparison of specific combinations, I’m happy to provide that as well.
