ᐅ Which Ikea Pax models are ideal for small homes?
Created on: 17 Jan 2022 10:23
Ginepau
Ginepau
17 Jan 2022 10:23
I am currently planning to make my small house more space-efficient. I am looking for suitable Ikea Pax models that work particularly well in small room sizes. I am especially interested in versions that stand out due to their flexibility in interior layout and compact dimensions, without losing storage capacity. Can you share any experiences with models or combinations you would recommend for small houses or tight rooms? Are there any special considerations for assembly or use that should be kept in mind?
I look forward to your tips and advice, especially regarding storage optimization and practical furnishing ideas for small spaces!
Daledra
17 Jan 2022 11:05
For small rooms, I recommend the narrow Pax wardrobe with a width of 50cm (20 inches) and a depth of 58cm (23 inches). It takes up little space and can be easily customized. Inside, you can flexibly combine shelves and drawers. Just make sure to plan the interior well, otherwise you might lose storage space.
Jensson
17 Jan 2022 13:42
Hello Ginepau,
to answer your question in detail, here is a brief guide:
1. Dimensions and space usage: For small houses, the Pax with a width of 50 cm (20 inches) is best suited, often with a height of 201 cm (79 inches). There are also versions with a height of 236 cm (93 inches) if you want to maximize storage vertically.
2. Interior layout: Use flexible interior components such as drawers, clothes rails, and shelves to make the most efficient use of the storage space.
3. Assembly: A common mistake is neglecting wall mounting—especially with taller Pax models, this is essential for safety.
4. Doors: Sliding doors save space but are more expensive and can be tricky to install. Standard doors with a small opening radius are often more practical in small rooms.
In summary, narrow Pax models with flexible interiors are ideal. If you have detailed dimensions and storage requirements, I’m happy to assist you with the planning.
Genevieve
18 Jan 2022 08:17
Jensson schrieb:
A common mistake is neglecting wall mounting – especially important for safety with tall Pax units.
This is an important point that I cannot emphasize enough. Wall mounting is often underestimated, especially in smaller houses with potentially thinner or uneven walls.
I also wonder whether the supposedly space-saving sliding doors are truly practical in the long run. Don’t regular doors have the advantage of allowing easier access and more flexible interior layouts? Sliding doors often seem to limit interior design options, which can be counterproductive, especially in small rooms.
What are your thoughts on this trade-off? Does anyone use Pax units with sliding doors in small rooms and can share whether the investment is worthwhile?
gilen
18 Jan 2022 14:49
I had a small older house myself with very limited storage space, so I spent a lot of time exploring the Ikea PAX system.
The following points helped me arrive at a good solution:
- The narrow frame with a width of 50 cm (20 inches), as already mentioned here, is truly invaluable. Since the depth is available in 35 cm or 58 cm (14 or 23 inches), you can choose shallower options depending on your room to maintain walking space.
- For small houses, I would also recommend interior fittings with baskets and adjustable shelves. This way, you can make very efficient use of the vertical space as well.
- Regarding doors: I chose regular hinged doors. They are easy to install, and you can customize the fronts individually. Sliding doors seemed too expensive to me, and the mechanism tends to require more maintenance.
- When assembling, be sure to anchor the wardrobes securely to the wall! Safety comes first, especially if you have children or uneven floors.
In conclusion, I can say that a few well-planned PAX units can make the room significantly cozier if you carefully measure and plan the storage space beforehand. The Ikea planner online is also a great help.
I hope this helps!
