ᐅ Which Ikea PAX models are best suited for adapting to sloped ceilings?
Created on: 21 Sep 2020 20:07
Lumu69
Lumu69
21 Sep 2020 20:07
I am currently facing the challenge of designing a walk-in closet with Ikea PAX wardrobes under a sloped ceiling. I am wondering which PAX models adapt best to sloped ceilings in terms of sizes, flexible interior configurations, and the possibility to cut or combine the wardrobes for a perfect fit.
I am especially interested in whether, based on your experience, there are models that are easier to modify or which constructions work better for angled walls. Are there certain widths, heights, or element combinations that you would recommend?
Additionally, I would appreciate any tips on how to adjust the wardrobes to maximize storage space without requiring extensive modifications to the cabinet carcass.
I look forward to your experiences and recommendations, including any advice on special parts or IKEA accessories that have proven useful for fitting wardrobes under sloped ceilings.
fiman
22 Sep 2020 06:35
In short: PAX units with widths of 50cm (20 inches) and 75cm (30 inches) are the most suitable. The 50cm (20 inches) modules can be easily stacked side by side and on top of each other to fit precisely against the slope.
Thanks to the folding doors, you can also choose doors that work well with tighter slopes.
A height of 201cm (79 inches) is best for flexibility.
lochen
22 Sep 2020 10:48
Hello Lumu69,
Your question is very practical, and I can fully understand that planning around sloped ceilings can be challenging. In my opinion, the PAX series offers the most flexibility with the narrower modules, especially the 50 cm (20 inch) width, as they can be easily combined side by side and stacked.
It is important to note that with sloped ceilings, the standard height of 201 cm (79 inches) often fits best because the floor rails are less complicated, and you can use cover panels to create a smooth visual finish.
Besides the narrower widths, there are also special sloped ceiling finishes and the option to customize the interior fittings. If you don’t yet know the exact angle of your sloped ceiling, it’s better to allow some extra space.
For adjustments, I also recommend attaching the back panels last during installation so you remain flexible when making modifications.
Sometimes it’s worth positioning the cabinets slightly in front of the slope and using a slanted cover panel to avoid losing storage space.
Hope this helps!
Guyju
23 Sep 2020 08:21
Hello Lumu69,
I would like to provide a more detailed explanation on adapting the Ikea PAX models for sloped ceilings, as I completed a similar project myself some time ago.
First, it is important to know the exact dimensions of the slope: the height at the lowest and highest points, including the depth of the slope. This will determine whether you can arrange multiple modules side by side or if it makes more sense to work with a combination of different heights using cover panels.
About the models: PAX wardrobes with a depth of 50 cm (20 inches) are often more practical because they do not appear too deep in small or sloped rooms. The width options of 50 cm (20 inches) and 75 cm (30 inches) fit best, as they create a modular grid that can be customized individually.
For example:
- Use 50 cm (20 inches) wide and 201 cm (79 inches) high frames for the higher parts of the slope.
- Combine next to them 50 cm (20 inches) high or lower wardrobes, depending on the height of the slope at each point.
There are no fully pre-made PAX elements for sloped adjustments, but you can camouflage unevenness by trimming the top cover panels and using baseboards with adjustable heights.
For doors, you can choose between hinged doors and folding doors. Folding doors are often more affordable and convenient in tight spaces under the slope.
Another tip: Although Ikea does not offer official special parts for sloped ceilings, many users combine the narrow carcasses with the PAX interior components (drawers, shelves, rods) and cut the cladding or cover panels to fit themselves.
To summarize:
- 50 cm (20 inches) depth + suitable widths (50 or 75 cm / 20 or 30 inches)
- Modular combination of different height frames
- Adjustment of cover panels
- Remain flexible with door types (folding doors)
If you want a completely professional result, a carpenter can trim the top parts to fit precisely, or you can plan angled fronts tailored to the slope, but that goes beyond the Ikea system.
I hope this overview helps you! If you can provide measurements or photos, I’d be happy to offer more specific advice.
Rensan3
23 Sep 2020 14:17
Guyju schrieb:
For doors, you can choose between swing doors and folding doors. Folding doors are often more affordable in tight spaces under sloped ceilings.
I agree with that. Folding doors also work better in areas where the slope is low.
Additionally, opting for cabinets with a depth of 50 cm (20 inches) helps to avoid taking up too much space.
Nauman5
24 Sep 2020 09:53
Lumu69 schrieb:
Are there recommended widths, heights, or combinations of elements?
Hey, that’s a really great question! I once built a small cabinet under a sloped ceiling myself, and I can say: The 50cm (20 inches) width is your best friend. You can easily customize it like building blocks.
lochen schrieb:
Sometimes it’s worth positioning the cabinets slightly in front of the slope and using a slanted cover to avoid losing storage space.
Truly, that looks more elegant and you don’t have to constantly deal with millimeter-precise work.
And if you want to try folding doors: Give them a go, they really make things convenient when the slope is in the way.
All in all: With PAX you’re on the safe side, it just takes the right setup and a bit of creativity. Good luck with your project, and keep us updated!
