ᐅ Which DIY ideas work well with assembling IKEA Metod kitchens?
Created on: 13 Jul 2024 08:27
Pudutar
Hello everyone, I am currently planning the layout of my new kitchen using the IKEA Metod system and am looking for ideas on how to complement or customize it effectively with DIY projects. I am especially interested in suggestions that work well with the modular design and typical structure of Metod. Are there smart additions, for example regarding space optimization, lighting, or surface finishing, that can be easily done as DIY? It is important to me that the DIY solutions do not put too much strain on the system but integrate well without compromising stability or functionality. Who has experience with this or can offer concrete tips on which DIY ideas are worth trying and practical to implement?
Palenar
15 Jul 2024 11:22
Regarding load capacity and reinforcement: Metod typically uses particleboard carcasses with aluminum connectors and special hinges designed for maximum weight. If you plan to hang additional loads, it’s best to start by reinforcing the attachment points. For example, you can add wood-reinforced panels to the back of the cabinets or use metal brackets that go beyond the usual screw points. It’s important to distribute the weight as evenly as possible and avoid concentrated overloads. One method I recommend is attaching metal profiles to the wall, then hanging the Metod carcasses on them. This way, the cabinets partially bypass their own weight, ensuring stable connections. If you build inner drawers yourself, I suggest using full-extension ball-bearing slides with high load capacity. One small but often overlooked detail: careful measuring during installation prevents misalignment, which can cause uneven loads that wear out hinges or slides faster. I hope this helps. If you like, you can share more details about your kitchen, and I’ll provide more specific advice on the interior fittings.
