ᐅ Which types of hardware are best suited for making Ikea BESTA units easy to move and adjust?
Created on: 19 Jun 2021 10:21
Tankirsten
Tankirsten
19 Jun 2021 10:21
I am planning to make my Ikea Besta system more mobile and flexible by adding casters. I’m wondering which casters are best suited to make the Besta system both stable and easy to move. It is important to me that the cabinet is not only easy to slide but can also support a certain load and does not leave marks on the floor.
I’m also interested in whether there are specific caster models that work better for different Besta sizes (for example, 120x40 cm (47x16 inches) or 180x40 cm (71x16 inches)) and if there are any important differences to consider between fixed and swivel casters.
If anyone has practical experience or can recommend certain types of casters that are especially durable or gentle on floors, I would appreciate any tips or feedback.
So, which casters are ideal for flexibly moving Ikea Besta units without sacrificing stability and functionality?
Thanks in advance for your help!
Kinbu
19 Jun 2021 11:13
Hi Tankirsten,
Regarding your question about the ideal casters for the Ikea BESTA system, I can share the following from experience:
- There are basically two types of casters commonly used: fixed casters and swivel casters (also called rigid casters and double casters).
- For a piece of furniture like BESTA, which can get relatively heavy, swivel double casters with locking brakes are highly recommended. These casters are sturdy enough to support the weight and still provide good maneuverability.
- When choosing, make sure the casters have a load capacity of at least 20 kg (44 lbs) per caster. Of course, this depends on the total weight of your unit, but this capacity is often reasonable.
- For your flooring, casters made of rubber or PU (polyurethane) are ideal, as these materials protect the floor and prevent scratches.
- A small tip: If you move the BESTA often but sometimes want to keep it stationary, casters with integrated brakes are very convenient.
Best regards and good luck with your renovation!
pauPierce
19 Jun 2021 15:46
Hello Tankirsten,
to provide well-founded advice on the best casters for the Ikea BESTA system, we should first clarify the basic conditions, as not every caster is suitable for every application.
The most important factors to consider when choosing casters are:
- Total weight of the BESTA furniture including contents
- Floor type (e.g., parquet, tiles, carpet)
- Desired mobility (how often it will be moved, how easily it should roll)
- Stability requirements (important for large surface modules)
Technically, I recommend casters with a load capacity of at least 30 kg (66 lbs) per caster for BESTA modules from 120 cm (47 inches) in length fully loaded, to avoid damage and ensure smooth movement.
Materials:
- Polyurethane casters are versatile and work well on hard floors; they reduce noise and protect the floor.
- Ribbed rubber casters are better for more sensitive floors but must not be too hard depending on the load.
Construction:
- Ball-bearing casters offer better maneuverability and durability.
Because:
- “For stable mobility, it is better to use swivel double casters with a large contact surface.”
- Another tip is to equip the casters with a locking brake to fix the furniture in place when needed.
One more question for you: What exactly do you plan? Do you want to move the BESTA module regularly (e.g., for vacuuming) or just occasionally rearrange it?
These details can significantly influence the choice of casters.
blapau
20 Jun 2021 09:37
I fully agree with that. Especially for furniture like the BESTA, which is often loaded with various items, stability is essential.
Another important point is the installation of the casters. It is advisable to choose casters with a sturdy mounting plate, as this distributes the force better onto the furniture frame. Also, make sure the casters are compatible with the underside of the BESTA, for example regarding the mounting holes or the ability to securely fasten the screws.
Furthermore, consider that the maximum total height of the caster must match the furniture height; otherwise, it may look unbalanced and the furniture could become unstable.
In summary:
- Swivel double casters with good load capacity
- Mounting plate with a robust fastening system
- Caster material suitable for the flooring
With these criteria, you will be on the safe side.
SETHBLA
20 Jun 2021 17:59
In short: For Ikea BESTA, I recommend swivel double casters with locking brakes. It is important that each caster has a load capacity of at least 20 kg (44 lbs) and features wheels made of rubber or polyurethane to protect the floor.
RonJarrett
21 Jun 2021 08:22
Kinbu schrieb:
Make sure to choose casters with a load capacity of at least 20 kg (44 lbs) per caster.
This recommendation is quite practical; however, I would like to add that depending on the size and load of the BESTA cabinet, a higher load capacity is advisable. Especially for larger modules (e.g., 180x40 cm (71x16 inches)) that are fully loaded, the weight can quickly reach 80–100 kg (176–220 lbs).
Based on my own research, I recommend:
- Casters with a load capacity of 30–40 kg (66–88 lbs) each
- Using 4 to 6 casters for even weight distribution
- Casters with ball-bearing swivel wheels for better maneuverability
Additionally, the mounting plate of the casters should be at least 6x6 cm (2.4x2.4 inches) to ensure secure attachment.
For floor protection, casters with polyurethane wheels are recommended because they are durable and gentle on floors. In comparison, pure hard plastic casters are often unsuitable for tile floors, as they can cause scratches.
My conclusion: A combination of high load capacity, appropriate materials, and sufficient mounting ensures a durable and flexible Ikea BESTA system.
