ᐅ How can I effectively remove scratches and wear marks from IKEA BESTA surfaces in a lasting way?
Created on: 20 Sep 2021 08:17
ATALAYPRA
Hello everyone, I have a detailed question about a topic that has been on my mind for a while: How can scratches and signs of wear on the surfaces of IKEA Besta furniture be removed in a lasting way?
I’m not just looking for short-term concealment, but for methods that work long term and cause as little damage as possible to the surface. The surfaces are usually melamine-coated or laminated, depending on the model and version, so I want to avoid harsh products that could damage the protective layer.
Does anyone have experience with specific care products, household remedies, or repair kits that work well with these materials? Any tips on preparation or application would also be great to ensure the solution lasts and you don’t have to start over soon.
Thanks in advance for your advice and opinions!
Hey everyone, here’s a quick tip: If you can’t completely remove scratches, using a bit of furniture polish and a color-matched wax stick often creates a great visual improvement!
You have a point there. But hey, if you regularly maintain your furniture, the results usually last quite a while. Sure, new marks will appear eventually, but that’s just part of it. The important thing is not to get discouraged and to keep at it!
ODINFLO schrieb:
Or are these measures mostly cosmetic and need to be repeated at some point? To me, sustainability implies a longer-term result.
For the maintenance and repair of melamine-coated surfaces, such as those on IKEA Besta furniture, I would like to add the following:
- Avoid aggressive mechanical methods like heavy sanding, as this can damage the protective layer.
- Repair kits should be specifically designed for melamine surfaces, as their resins and waxes are specially formulated.
- If the surface has become dull, treatment with a specialized plastic care product can help; it both protects and slightly restores the finish.
- Always test new products on an inconspicuous area first to prevent unwanted effects.
These tips are based on current product recommendations from the furniture care industry.
I just wanted to mention that patience is really important when applying repair products! Some repair materials need time to dry properly so that the surface is optimally protected.
Although it may require a bit more effort at first, it pays off in the long run. And your BESTA furniture simply looks much fresher after the treatment! 👌
ATALAYPRA21 Sep 2021 12:05Thank you very much for all the detailed and thoughtful responses! Your advice on choosing repair materials and maintenance is very helpful.
I find this point very important and agree that repaired areas should be easy to touch up over time, while keeping the effort as low as possible.
Does anyone have specific product recommendations? Especially for wax sticks or repair kits that have proven effective and are as low in harmful substances as possible? And how long do your successful repairs typically last?
ODINFLO schrieb:
For me, sustainability implies a long-term result.
FRANCISCOP21 Sep 2021 13:27Regarding product recommendations:
- The Toso furniture kit for melamine surfaces is frequently recommended and delivers reliable results.
- There are also kits based on beeswax that provide a mild surface sealant at the same time.
Regarding durability: Under normal use, repairs generally last from several months up to a year, depending on the wear of the furniture surface. Regular maintenance helps extend the effect.
Before purchasing, check the ingredients to avoid solvents as much as possible, since they can damage the plastic.
