ᐅ Which alternative materials are suitable for IKEA Besta fronts?
Created on: 24 Jan 2023 09:13
GOTINU
GOTINU
24 Jan 2023 09:13
I am planning to renovate my IKEA Besta fronts and want to use alternative materials that are either more durable or better match my interior design concept. The standard fronts are usually made of particleboard with a foil coating or paint. I am especially interested in materials that can be easily cut and attached to the cabinet without losing the functionality of the handles or hinges.
Does anyone know suitable materials for fronts? Important aspects to consider are:
- easy processing or machining with tools I have at home
- resistance to scratches, moisture, and everyday wear
- cost-effective alternatives that still offer a visual upgrade
I look forward to your experiences and recommendations. Thank you!
blapau
24 Jan 2023 11:18
For IKEA Besta fronts, MDF boards with a laminated or painted surface are particularly suitable. They provide a stable base, are easy to work with (sawing, sanding, drilling), and can be finished with various surface coatings. Alternatively, HPL (High Pressure Laminate) is also a good option, as it is highly resistant to moisture and abrasion.
It is important to properly seal the edges, as the material can easily absorb moisture otherwise. When assembling, appropriate fasteners should be used to securely attach the fronts.
roryvin
24 Jan 2023 13:42
As a supplement: besides MDF, coated plywood or multiplex can be used as front materials. Both are durable and can be sanded and painted. Multiplex is somewhat more expensive but offers greater stability and a natural wood appearance.
When choosing the material, thickness should also be considered. Ideally, it should be around 12 to 19 mm (0.5 to 0.75 inches) to ensure solid strength without unnecessary weight.
Additionally, melamine resin-coated wood-based panels can be used very effectively. They are scratch-resistant and easy to maintain, but require more careful edge processing.
GOTINU
25 Jan 2023 08:07
blapau schrieb:
Alternatively, HPL (High Pressure Laminate) is also interesting because it is very resistant to moisture and abrasion.
That sounds good – but what about the mounting? HPL is just the surface layer that you glue onto a substrate board, right? So should I plan to use MDF as the base board and apply the HPL on top? And how complex is the additional equipment needed for bonding? Also, what about the edge thickness? Will standard fittings, like those from IKEA, still be compatible?
Thanks for any further advice!
LOGEMIN
25 Jan 2023 12:29
Here is a brief overview:
- Base panel: MDF or plywood (MDF is more affordable, plywood is more durable)
- Surface: HPL as a durable layer that is glued on; acrylic paint for a smooth look and scratch resistance
- Edge protection: ABS or PVC edging strips for protection and a neat finish
Tip for gluing panels together: Use special contact adhesive or PU glue, and always check for squeeze-out marks to ensure proper bonding. Otherwise, the surface will not hold well. For fastening, the original hinges can be used if the material thickness is taken into account. For thicker fronts, longer screws may be necessary.
Common issue: Using panels that are too thin can cause the front to warp. Also, sanding the edges carefully is essential; otherwise, the glue bond will be weak.
Luchen
26 Jan 2023 07:55
Use 12mm (1/2 inch) MDF as a base, glue HPL on top, and seal the edges with PVC strips. Original fastenings remain, only longer screws are necessary.
