ᐅ Which additional shelves are best suited for a PAX wardrobe?
Created on: 14 Nov 2019 08:37
kylenau
kylenau
14 Nov 2019 08:37
I currently have a standard-sized PAX wardrobe from IKEA measuring 150 x 236 cm (59 x 93 inches). I would like to better customize the interior to suit my needs and am wondering: which additional shelves or shelf boards fit best in a PAX wardrobe to create optimal storage space? It is important to me to choose sturdy, durable options that are easy to install and, above all, compatible with the existing peg holes.
I am looking for recommendations or experience-based advice on suitable shelves that work well together, as well as tips on what to consider when purchasing (material, load capacity, depth).
Thanks in advance for your suggestions!
Ryker66
14 Nov 2019 09:12
The standard shelves from IKEA fit best. If you want additional storage space, it’s best to use the fixed shelves they offer for PAX. These have the perfect depth and fit securely into the peg holes.
O
onan56
14 Nov 2019 10:05
That’s true, but personally, I sometimes find it a bit frustrating to only use the standard shelves without being able to customize anything. Especially if you have specific requirements, it can be stressful because the selection is limited.
I’ve tried adding extra shelves myself, but sometimes they’re just too wide or the hole rows don’t match. I had to do quite a bit of trial and error.
So I’m interested to hear if anyone has tips on how to use more customized shelves without damaging the entire system or losing stability.
LEVI41
14 Nov 2019 11:29
To answer your question objectively: the best additional shelves for the PAX wardrobe are the original IKEA shelves, as they are precisely designed to fit the hole spacing and dimensions.
You should only use alternative shelves if they meet the following criteria:
- Suitable dimensions (depth 58 cm (23 inches) for standard PAX)
- Compatible hangers for the hole rows or custom mounting solutions
- Load capacity of at least 15 kg (33 lbs) per shelf
Typically, sturdy MDF boards with a thickness of at least 16 mm (0.63 inches), which can be fixed with hole-row adapter sets, are suitable.
Modular systems available in specialty stores can also be customized. However, there is a higher risk that they will not fit perfectly. From an economic point of view, the original IKEA shelves are usually the best choice in terms of price and exact fit.
tetan
14 Nov 2019 13:44
I can only agree with LEVI41. If you want additional shelves, stick with the IKEA PAX accessories. They fit perfectly and hold well.
Other shelves may cause issues with mounting. Better not to improvise if you want stability.
koduga
15 Nov 2019 08:17
onan56 schrieb:
I tried adding extra shelves myself, but sometimes they are just too wide or the peg holes don’t match.
I know the feeling well. You just want more storage space, but the standard shelves often aren’t flexible enough, especially if you want to store shoes and clothes in a versatile way.
In the end, I had custom shelves made from veneered plywood and installed them in the PAX wardrobe using suitable metal brackets. It worked better than expected and everything looks very sturdy. But I admit, that’s a bigger project.
If you don’t want to do that kind of DIY, the IKEA accessories are probably the easiest solution.
I’m curious if anyone here has experience with extensions made from other materials (for example, metal frame shelves).
