ᐅ Which Ikea Pax interior fittings are suitable for a home office?
Created on: 10 Sep 2023 09:23
NASH62Hello everyone, I am currently considering how to efficiently integrate my home office workspace into an Ikea Pax wardrobe. I am especially interested in which interior fittings of the Pax system are best suited to create a neat and functional work area.
I imagine needing storage space for folders, technology (laptop, docking station, cable management), as well as room for a small pull-out desk or at least a work surface.
Does anyone have experience or recommendations on which Pax interior fittings work particularly well for this purpose? What dimensions and combinations of shelves, drawers, units, or clothing rails are most practical? And are there any tips for good internal organization that are particularly useful for a home office?
I look forward to your constructive contributions!
The Pax wardrobe is generally flexible, but for a home office, an interior setup with the following components is recommended:
- Shelves at various heights for storing binders and books
- Drawer inserts or boxes for office supplies
- Optionally, a pull-out work surface or sliding table
- Cable management systems, either added separately or through drilled openings
The shelf dimensions should correspond to common binder sizes (approximately 30 cm (12 inches) wide, 25–28 cm (10–11 inches) deep). It is important to take accurate measurements of devices and work materials before purchasing.
To thoroughly cover the topic: The Ikea Pax wardrobe offers a huge variety of internal components that can be very useful for home office purposes if you make good use of the available space.
First, you need to determine how much room you have and whether the wardrobe will serve as your primary workspace or as a supplement to a traditional desk. If the Pax is intended to be the main workstation, I recommend the following steps:
- Planning the work surface: A pull-out table or a fold-down panel is ideal. Unfortunately, Ikea does not offer an official pull-out shelf within the Pax system, so alternatives or custom solutions need to be considered.
- Storage for technology: Cable management is often underestimated. Built-in cable passages or separate cable channels help prevent tangled cords.
- Drawers with adjustable compartments for paper clips, pens, etc., are useful; I recommend at least two flat drawers.
- Shelves for binders: Make sure to adjust the shelf heights according to the binders, after accurately measuring the internal depth and width of the wardrobe.
A combination of wide shelves for files and small drawers for accessories is almost always a practical solution. The height of the wardrobe is also important: taller models allow you to use the upper shelf for items you rarely need.
Finally, a regular practical check to ensure the workspace remains ergonomic is essential. Otherwise, it’s easy to end up with clutter inside the wardrobe, which can become more of a nuisance over time.
One more question for the thread starter: How large is your Pax wardrobe, and which hardware do you want to integrate exactly?
kulau schrieb:
One more question for the thread starter: What are the dimensions of your Pax wardrobe and which hardware exactly do you want to integrate?Thanks for the detailed answer, kulau. I have planned a Pax wardrobe measuring 100 cm (40 inches) wide, 60 cm (24 inches) deep, and 201 cm (79 inches) high. The hardware mainly includes a laptop with a docking station, some cables, USB hubs, a small printer (around 40 x 30 cm / 16 x 12 inches), and of course folders and office supplies.
A pull-out desk would be ideal if it fits within the width. Cable management is also very important, as I don’t want the overall appearance to look messy. I’m also considering improving the interior lighting—do you have any suggestions?
I would also be interested in experiences with cabinets that hold a vertically standing laptop, since I plan to use my main workspace with an external keyboard and monitor.
Regarding cable and technology organization: The Pax system has power strips that can be easily secured to the side or back panels using cable ties.
You can retrofit a flap on the back panel for cable passthroughs if Ikea does not offer this option.
For lighting, I recommend LED spotlights or clip-on lights with rechargeable batteries, which can be simply attached to the inside surfaces. This keeps things flexible without cable clutter.
About storing a laptop upright: There are laptop stands or sleeves designed to be stored vertically in a compartment. Make sure the internal dimensions for width and depth fit well to prevent the device from wobbling.
In summary: Plan your tech components carefully and arrange the interior of the Pax system flexibly for quick and easy access to everything.
