ᐅ What should you do if the doors of your Pax wardrobe do not close properly?
Created on: 13 Sep 2018 08:37
Burenu
I have noticed that the doors of my Pax wardrobe no longer close properly. Specifically, they sometimes get stuck and don’t close flush, instead sticking out slightly. This is especially frustrating because it makes the wardrobe look untidy and the magnetic or latch mechanisms don’t work reliably.
Do you have any experience or tips on the best way to handle this situation? I suspect the hinges might need adjusting, but it could also be due to warped door panels or the door inserts. It would also be helpful to know if it’s worth checking the frames or the wardrobe structure itself before attempting more extensive repairs.
Thank you in advance for your help!
maflo
15 Sep 2018 10:13
I’ll try to summarize the topic and also share some practical tips that I have personally used. If the doors of the Pax wardrobe don’t close properly, I recommend the following steps:
- First, open and close the door by hand to identify the exact issue: Does the door stick, close crookedly, or jam somewhere?
- The next step is to adjust the hinges:
- Ikea usually uses metal hinges on Pax with three adjustment screws that allow you to adjust vertically, horizontally, and in depth.
- It’s best to use a Phillips screwdriver and make small adjustments step by step.
- Check the door for visible damage, especially on the edges or around the frame.
- The hinge mounts on the cabinet frame should be secure, as they often loosen over time.
- For magnetic catches: clean the contact surfaces with a dry cloth, since dust can reduce holding power.
One common mistake I have seen is that the doors are sometimes hung incorrectly—so definitely double-check the installation according to the instructions.
Finally, if none of this helps, warped doors or broken hinges might be the cause. Replacement parts are usually easy to get directly from Ikea.
I hope this helps!
