ᐅ What should you do if the doors of your Pax wardrobe do not close properly?
Created on: 13 Sep 2018 08:37
Burenu
Burenu
13 Sep 2018 08:37
I have noticed that the doors of my Pax wardrobe no longer close properly. Specifically, they sometimes get stuck and don’t close flush, instead sticking out slightly. This is especially frustrating because it makes the wardrobe look untidy and the magnetic or latch mechanisms don’t work reliably.
Do you have any experience or tips on the best way to handle this situation? I suspect the hinges might need adjusting, but it could also be due to warped door panels or the door inserts. It would also be helpful to know if it’s worth checking the frames or the wardrobe structure itself before attempting more extensive repairs.
Thank you in advance for your help!
PIN66
13 Sep 2018 09:05
Hello Burenu,
First of all, your suspicion that the issue might be with the hinge adjustment is very likely. Pax doors usually have three adjustment options on the hinge: vertical, horizontal, and depth.
- First, check if the screws on the hinges are tight.
- Then, use a suitable screwdriver to turn the adjustment screws to raise or lower the door.
- Check if the door is warped. If it is, replacement is the only solution.
It could also be that the cabinet frame is slightly warped, which affects the door alignment. In this case, check the level using a spirit level or a straight edge.
One more tip: Sometimes it helps to check the cable ties or fasteners on the back of the doors, especially with sliding doors that have a frame.
If your cabinet has magnetic catches, also check whether the magnets are still properly aligned or if they are obstructed by dust or debris.
Feel free to let me know the exact situation, so I can assist you more precisely.
baelku
13 Sep 2018 09:21
Hello Burenu,
First, check the hinges. Carefully adjust the screws to align the door flush. If the door is warped, replacement is the only solution.
sanpar58
13 Sep 2018 11:44
Hello Burenu,
I understand that this can be frustrating. Often, it is actually a combination of several factors:
- Check the hinges to ensure they are securely fitted and adjust them if necessary.
- Inspect the doors for warping, especially with MDF-coated versions.
- See if anything is misaligned in the cabinet frame or on the base that could be blocking the door.
- Clean the contact points of the magnetic catches, if present.
Sometimes an obstacle between the door and frame, such as paint residues or small wood chips, can be the cause.
If you feel unsure about adjusting the doors, I’m happy to help with a step-by-step guide.
Gilbert
14 Sep 2018 07:29
I want to raise a somewhat provocative question: Why should the doors of an Ikea Pax, a Swedish mass-produced product, close perfectly over time without any adjustments?
Burenu schrieb:
I suspect that the hinges might need adjusting, but it could also be due to warped door panels or the door inserts.
Exactly, that hits the nail on the head. In my opinion, the problem often lies in the expectations: people expect Ikea wardrobe doors to close like an expensive custom-made cabinet. However, these wardrobes cost only a fraction of that – and the quality reflects that.
Anyone who truly expects a perfect fit will have to make regular adjustments themselves. This is not a flaw but rather normal, and it is also very easy to do on your own.
My recommendation is to simply accept that the product has certain tolerances and learn to live with small adjustments.
Neogi
14 Sep 2018 11:57
Interesting, Gilbert, that you see it that way, but I believe the expectation for stable and durable functionality is definitely justified, especially when the cabinet is considered part of the home furnishings.
Gilbert schrieb:
Anyone who really expects a perfect fit will have to regularly adjust it themselves.
My approach would be: Why should the consumer have to do that? Shouldn’t quality and design ensure this instead? Such readjustments sound to me like a hidden defect.
Have you or anyone else found out whether there are technical documents or improvements from Ikea itself? I’m asking because I think standards or developments should be questioned here and not simply dismissed with DIY solutions.
