ᐅ What types of seals are available for the doors of the Pax system?
Created on: 6 Nov 2023 18:47
ELRILEOHello everyone,
I am currently working on a project to seal the doors of my Ikea Pax wardrobe to better protect against dust and drafts. I am particularly interested in the different types of seals available for Pax doors. What options are technically available, and how do they differ in terms of material, fit, and installation? Also, how does the choice of seal affect the use of the wardrobe, for example regarding the opening mechanism or durability?
It would be great if you could share your experiences or knowledge on this, including any tips about potential installation challenges or drawbacks of certain types of seals.
Thanks in advance!
Thanks in advance!
There is a lot to consider regarding this question, as the choice of the appropriate seal for Pax doors depends on several factors.
First, there is the type of door: whether it is a hinged door, sliding door, or folding door, since the seal varies significantly in profile and function depending on the design. Usually, the following seals are used:
- EPDM rubber profiles: Highly resistant to weather conditions and offer good elasticity. Particularly suitable for hinged doors.
- Foam seals made of polyurethane or PVC: Easy to cut and install but less durable.
- Brush seals: Commonly used on the edges of sliding doors to seal small gaps.
The choice of material affects not only the sealing but also sound insulation and how smoothly the door opens and closes.
An important aspect during installation is the correct cutting of the seal and precise fitting to avoid deformation or misalignment. Otherwise, the service life will deteriorate quickly.
I would be interested to know which type of door you are using. That way, the advice could be made more specific.
What an exciting topic! I love it when you can improve practical things like this! 😄 I used EPDM seals for my wardrobe myself and I'm really happy because the doors now close much better and the cabinet is properly sealed. You can totally notice the difference! Just stick it on and you're done! 👌 Of course, it takes a bit of patience when measuring, but it’s definitely worth it!
A small tip from my experience: If the seal is too thick, it can cause the cabinet door to be harder to open or even stick. Especially with swing or folding doors, it’s better to choose thinner seals or install the seal in a way that still allows enough clearance for the door. 😉 This way, functionality and comfort are preserved!
Briefly, my usual structured input:
1. Determine the type of door – hinged door, sliding door, or folding door.
2. Select the material:
- EPDM (rubber): Very durable, UV-resistant, ideal for dust- and airtight sealing.
- Foam: Flexible, easier to cut, but subject to wear from friction.
- Brush seal: Reduces gap under the door, less effective against drafts, more of a dust barrier.
3. Installation: Prepare the surface carefully, cut the seal precisely, ensure firm adhesion without trapping air.
Common error No. 1: Surface irregularities are often overlooked, which significantly reduces the sealing. Please sand smooth before installation.
Finally: After installation, thoroughly test the door’s operation in various open positions to avoid any tension.
