ᐅ What to do if the Ikea Metod drawers stick after installation?
Created on: 21 Oct 2020 10:37
Mejonte64
I recently installed a new kitchen with Ikea Metod drawers. I noticed that some of the drawers stick or do not slide smoothly when opening and closing. I suspect that the rails may not be properly aligned, or perhaps the drawer runners are slightly warped.
What are the most common causes for Metod drawers sticking after installation?
And what specific steps can I take to fix the problem myself?
Are there any special considerations I should keep in mind when adjusting or realigning the rails?
I look forward to your experiences and practical advice. Thanks in advance!
KUDAISY
23 Oct 2020 08:04
RonJarrett schrieb:
My tip: Use a spirit level to check the alignment of the drawer slides. The drawers must run perfectly straight.
That is absolutely correct. I would like to add some tips on how to adjust them optimally:
- Remove the drawer completely and check the mounting brackets of the slides.
- Use the spirit level to also check the side walls, ensuring they are truly vertical.
- The slides have small clips underneath for fine adjustment, which should be used.
- Pay attention to how the drawer “clicks” into place when inserted. Resistance in only one spot indicates uneven seating.
Landontau schrieb:
Carefully mount the front panel and adjust it using the built-in adjustment screws (top/bottom and left/right).
These screws are invaluable for fine-tuning the front panel, especially if there is friction between the front and the cabinet carcass.
Finally: If the problem occurs with multiple drawers, it is worth checking the entire cabinet with a spirit level. Any unevenness in the floor can affect the drawer’s sliding direction.
