ᐅ How to Clean Stubborn Dirt on BILLY Shelves?
Created on: 5 Nov 2024 08:37
GIDAN1
I have a rather specific issue with my Billy shelves from IKEA, namely stubborn stains that won’t come off despite multiple attempts to clean them. The shelves are made of the typical melamine-coated wood-based material, and the stains sometimes look like burned-in drink rings or somewhat oily dirt that seems to have penetrated deep into the surface.
Does anyone have experience with effectively removing such stains without damaging the surface? I’m hesitant to use harsh cleaners because I want to preserve the appearance of the shelves.
Thanks in advance for any helpful tips!
Nabla64
6 Nov 2024 08:22
Hello GIDAN1,
I would like to provide you with a practical step-by-step guide on how to remove stubborn dirt from your BILLY shelves without damaging the melamine surface:
1. Preparation:
- Make sure you have a soft, lint-free microfiber cloth and a sponge with a soft surface.
- Test cleaning agents on an inconspicuous spot first.
2. Cleaning with mild agents:
- Mix lukewarm water with a drop of mild dish soap.
- Wipe the surface thoroughly and let it dry briefly.
3. Applying baking soda paste:
- Mix baking soda with a little water to form a creamy paste.
- Gently apply the paste to the stains with a damp cloth.
- Rub in circular motions, using only light pressure.
- Afterwards, remove any excess residue with a clean, damp cloth.
4. Isopropyl alcohol for particularly stubborn stains:
- Use a cotton swab or soft cloth soaked in isopropyl alcohol.
- Dab lightly, do not wipe over large areas to avoid drying marks.
5. Finishing treatment:
- Finally, wipe the surface with a dry microfiber cloth to remove moisture.
Important: Avoid abrasive cleaners with coarse grains, steel wool, or aggressive chemicals as they can damage the melamine coating!
If you have questions about any of the steps, I’m happy to help.
Davidleo
6 Nov 2024 09:40
Nabla64 schrieb:
Please avoid steel wool or harsh chemicals, as they can damage the melamine coating!
Exactly! At first, I tried too much and ended up with small scratches – that was really unfortunate!
But you can remove a lot with simple household remedies. Fingers crossed for you, GIDAN1! You’ll see, the shelves will soon shine beautifully again! 🙂
Filippo
6 Nov 2024 11:17
GIDAN1 schrieb:
So far, I haven’t tested isopropanol or vinegar, but I would like to try them carefully without making the surface dull or stained.
That is a very sensible approach. To avoid the risk of dull spots, I recommend using isopropanol sparingly and always wiping it off immediately with water. Vinegar, on the other hand, can cause melamine to become matte over time, so it’s better to leave it on only briefly and wipe thoroughly.
I would not advise applying either directly on large areas. It’s better to treat spots selectively and keep contact times short.
If you like, you can also describe which cleaning agents you have used so far, so we can help by process of elimination.
GIDAN1
7 Nov 2024 07:59
Filippo schrieb:
If you want, you can also describe which cleaning products you have used so far
So far, I have used basic all-purpose cleaners from the brand XYZ (pH-neutral according to the packaging) and regular dish soap, usually soap solution with warm water. I have avoided scrubbing vigorously with scouring pads to prevent scratches.
After reading your posts, I will test vinegar water diluted 1:1 in an inconspicuous spot and then, if necessary, switch to the baking soda paste.
Thanks in advance for the helpful tips!
