I have an IKEA Metod kitchen countertop made of white-coated wood-based material that has unfortunately developed some fine scratches. I am interested in learning how to effectively remove or at least visually reduce these scratches without causing permanent damage to the surface. What methods or products would you recommend for treating scratches on this type of countertop? Are there any specific care instructions I should follow to prevent the situation from getting worse? I’ve read that special cleaners or polishing compounds might help, but I am unsure because the countertop does not have a solid wood surface. Thanks in advance for your tips and experiences!
Here is a structured guide for treating scratches on IKEA Metod countertops:
- Cleaning: Start with a damp microfiber cloth and a mild dish soap to remove dust and grease.
- Light scratches: Apply furniture polish or furniture wax specifically designed for plastic or melamine surfaces sparingly, then gently buff with a soft cloth.
- Moderate scratches: A repair marker in a matching color can help conceal the damage. Clean and dry the area beforehand.
- Deep scratches: Caution is advised—often IKEA recommends having these areas repaired by a professional carpenter or replacing the damaged countertop.
It is important to avoid using aggressive abrasives or purely mechanical sanding methods, as these can damage the surface coating underneath.
Summary: Clean – use furniture polish – apply repair marker – consider replacement for severe damage.
Thanks for the tips so far; the approach with furniture polish and repair markers sounds promising. The scratches are actually quite superficial, but they become clearly visible in strong light. I will try the advice with gentle cleaning and wax. If I gain more in-depth experience with the repair markers, I’ll report back. Does anyone have experience with applying the repair markers multiple times if the color fades after a while?
luigiri schrieb:
Does anyone have experience with whether touch-up pens can be reapplied multiple times if the color fades after a while?Touch-up pens can theoretically be used multiple times. It is important that the surface remains clean and dry between applications. For superficial scratches, the repair often lasts several months to years, depending on usage and maintenance. Reapplying is therefore possible and advisable to maintain the appearance over the long term.
luigiri schrieb:
Does anyone have experience with whether repair sticks can be applied multiple times if the color fades after a while?Yes, this is generally possible. Before each reapplication, the area should be carefully cleaned to remove old paint and grease. Cleaning with isopropyl alcohol in between is helpful. I also recommend applying a thin layer and allowing it to dry thoroughly—applying thick layers repeatedly can look unnatural. Another good method is to lightly seal the repaired area with furniture polish after it dries, to help the color last longer.
