I am considering modifying some Ikea Hemnes furniture to better suit my living situation. I am especially interested in tips and tricks for making Hemnes dressers, shelves, or beds more functional or visually personalized. I am particularly looking for technical advice, such as regarding stability, material working, and appropriate tools, but design ideas and creative approaches are also welcome. Who has experience modifying Hemnes furniture and can provide well-informed advice on what to watch out for and how to avoid common pitfalls from the start?
Hey kajudah, this is a really exciting topic—I love modifying IKEA furniture! 😊 For Hemnes, I can already tell you that stability is key: the wood is mostly solid pine, but sometimes combined with particleboard, so be careful when working on it to avoid splintering or breaking. My advice: use screws and dowels for reinforcement, as glue and nails alone won’t be strong enough! Also, if you want to use paint, always sand thoroughly beforehand to ensure good adhesion and prevent peeling. And don’t be afraid to update the fronts—adding new handles or even wooden trim can make a big difference! Don’t get discouraged— with a little patience, you’ll end up with a really beautiful, customized piece of furniture! Good luck!
Hello kajudah, I’m happy to add some structured guidance for modifying Hemnes furniture:
First, you should carefully examine the construction of the specific piece, as Hemnes is usually made from solid wood panels with a thin back panel. This means that when making changes, especially if you want to reposition shelves, the pre-drilled holes are fixed and spade bits should be used carefully to avoid compromising stability.
It is also important to pay attention to the original tongue-and-groove joints at the corners. If you try to remove or re-drill these areas, you will lose stability.
For surface treatment, I recommend lightly sanding the piece first with 120-grit sandpaper to remove the lacquer layer and allow paint to adhere better later. After that, you can use wood filler to repair small imperfections.
Suitable tools are cordless drills with depth stops to prevent drilling too deep, and standard wood drill bits.
Summary:
- Study the construction carefully and respect connection points
- Avoid uncontrolled drilling in load-bearing areas
- Sand the surface thoroughly
- Use wood filler for small damages
- Replace handles and fittings for a fresh look
Good luck with your modification!
Summary:
reoWilhelm24 Dec 2016 18:48LEOPAU schrieb:
Cordless drills with depth stops are ideal to avoid drilling too deep, along with standard wood drill bits.Exactly! I completely agree regarding the tools. You’ll quickly realize that a regular cordless drill without a depth stop can be risky — drill too deep once, and just like that, the nice finish is gone. 😉
Here’s a little tip: if you want to refresh old wooden furniture, try using chalk paint or milk paint. Hemnes furniture is so sturdy, these paints work really well and give that rustic or upscale vintage look many people like.
Also, make it interesting by mixing different materials! For example, I covered the front edge of the shelves on a Hemnes unit with a thin steel sheet — it turned out totally unexpected and modern! Don’t be afraid to try something unconventional, especially with Ikea furniture, where there’s very little that can go wrong. Have fun!
Hello kajudah, here are some quick tips for your Hemnes renovation:
- Use wood screws instead of nails
- Pre-drill holes for dowels
- Prime all surfaces thoroughly before painting
- New handles and knobs instantly give a fresh look
- For a sturdy renovation: attach wooden battens for reinforcement
Good luck!
Good luck!
