ᐅ What should I do if the screws for Ikea PLATSA break?
Created on: 10 Mar 2018 19:03
Mireson
Mireson
10 Mar 2018 19:03
Hello everyone, I’m currently assembling my Ikea Platsa furniture and getting really frustrated because several screws have broken while screwing them in. Has anyone experienced this problem before and can advise me on the best way to proceed when Ikea PLATSA screws break? Should I try to remove the broken screws somehow, get replacements, or are there other practical solutions to keep the structure solid and secure? Looking forward to your tips!
barEsperan
10 Mar 2018 19:47
If screws break, first try to remove the screw head with a special extractor. If that doesn’t work, Ikea usually provides replacement screws, or you can look for a suitable replacement at a hardware store. Do not use force, as it will only make things worse.
anno58
11 Mar 2018 08:11
Hello Mireson, I am familiar with the problem of broken screws in PLATSA. First, it is important to carefully inspect the damaged area to avoid causing further damage. If the screw is embedded in the wood and the head has broken off, a screw extractor often helps. Alternatively, you can try to gently grip the remaining part with small pliers and pull it out. Ikea usually provides replacement screws without any issues if you can no longer use the original parts. The key point is not to compromise the stability of the furniture – it’s better to proceed carefully and, if in doubt, get replacement parts.
ladali
11 Mar 2018 10:24
anno58 schrieb:
If the screw is embedded in the wood and the head is broken off, a screw extractor often helps.
That is absolutely correct. Additionally, I recommend carefully checking the drill diameter and the depth of the screw before using a screw extractor to avoid unnecessary damage. Ikea PLATSA uses standardized fasteners; replacement screws should match the originals exactly – these can be obtained relatively easily by contacting Ikea customer service. For broken screws, it is best to work in small increments and use precise tools to prevent further damage.
Elodie
11 Mar 2018 14:39
Mireson schrieb:
Has anyone ever had the problem and can tell me the best way to proceed if Ikea PLATSA screws break off?
Oh man, these small tricky screws can be really frustrating when they break – almost a classic issue with furniture assembly, right? My advice: grab a small screw extractor from your toolbox, work carefully, and once you have removed the remains, just ask Ikea for replacement screws. They are usually quite accommodating with cases like this. And very important: don’t force it too much, or the furniture might not hold together properly. Good luck, you can do it!
JAMESONB41
12 Mar 2018 09:56
ladali schrieb:
Ikea PLATSA uses standardized fasteners; replacement screws should match the original exactly
Request replacement screws from Ikea and remove them carefully. Use a screw extractor if the head is broken off. This is the safest method.
