ᐅ What should be considered when transporting Ikea Pax wardrobes?
Created on: 10 Jan 2015 09:37
jepikau
I am planning to get an Ikea Pax wardrobe soon and I have some questions about transporting this piece of furniture. Specifically, I want to know the dimensions and weight I should expect, whether it can be transported fully assembled, or if it must be disassembled. Additionally, I would like to know the best way to protect the delicate parts, such as the wardrobe doors or fittings, to prevent damage during transport. Are there also any tips regarding the type of vehicle for transport or tools that can make moving it easier? I look forward to detailed answers and personal experiences!
Klakar
10 Jan 2015 13:26
Dowels are the weak points during transport, so always disassemble them. Remove doors, shelves, and the back panel. Then secure everything with strong straps to prevent shifting. This way, you avoid damage.
deoke
11 Jan 2015 08:45
jepikau schrieb:
Are there risks that the cabinet body might get damaged? Or should I better disassemble the entire cabinet?
If you only remove the doors and leave the cabinet body assembled, there is a relatively high risk of stress on the connecting parts—especially on uneven roads or during sharp turns. The load capacity of the connectors (dowels, cam locks) is designed only for static loads, not for lateral movements.
Therefore, I recommend disassembling the cabinet as completely as possible, especially for a height of about 2.36 m (7 ft 9 in), as this makes it easier to assess and protect its stability.
It is also important to handle the back panel carefully, as it is often attached only with small nails that must not tear or come loose.
If complete disassembly is not possible, secure the cabinet body firmly at stable points and brace it against twisting. If necessary, stabilize it against movement using wooden battens or straps.
Johnathon
11 Jan 2015 10:12
In addition to the previous advice: I have personally transported furniture like the Ikea Pax several times and have had the following experiences:
- The correct order for disassembly: first the doors, then the shelves, followed by the side panels, and finally remove the back panel.
- Remove the back panel carefully, as most transport damage occurs here.
- During transport, store the cabinet as upright as possible; lying it down increases the risk of deformation.
- Edge protection is essential, especially on the corners and edges of the doors and carcass parts.
- Use tension straps, preferably ratchet straps, to ensure nothing shifts.
Therefore, if space allows, it is better to disassemble, especially for longer transport distances or on uneven roads.
Can you say how long the transport route is?
jepikau
11 Jan 2015 11:03
The transport distance is about 40 kilometers (25 miles), mostly urban with some sections on the highway. Therefore, normal fluctuations and somewhat more potholes on country roads can be expected. Thanks for the tips on disassembly and packaging! I will take the wardrobe apart as much as possible, especially removing the doors and shelves.
deoke schrieb:
It’s also important to handle the back panel carefully, as it is often fixed only with small nails, and these should not tear or come loose easily.
Could you possibly add how to best secure or reinforce the back panel to ensure it survives transport without damage?
