ᐅ What is the best screw length for IKEA Platsa?
Created on: 4 Apr 2024 18:23
O
Onrota
O
Onrota
4 Apr 2024 18:23
I am currently planning to assemble my IKEA Platsa wardrobe and am wondering which screw length is best suited to ensure optimal stability and load capacity. The screws provided seem somewhat short to me, considering the expected stress and the connection between the individual modules.
My question is: What screw length is recommended for assembling the IKEA Platsa system? I am especially interested in whether it makes sense to use longer screws, what material thickness is advisable, and if certain types of screws (e.g., particleboard screws or wood screws) are preferable.
It would also be helpful to know if there are any known issues with screws that are too short or too long, such as damage to the material or weaker fixation.
Thanks in advance for your insights and advice!
lisku
4 Apr 2024 19:07
For Platsa, usually 4 x 50 mm (2-inch) chipboard screws work best. Longer screws might damage the material, while shorter ones do not hold securely enough. Make sure that the screws are specifically designed for furniture.
Jensson
5 Apr 2024 09:38
Hello Onrota,
I’m happy to help you with a more detailed explanation. For the IKEA Platsa system, chipboard screws are generally the right choice because they are specifically designed for the material (chipboard).
- The usual lengths I recommend are between 40 and 50 mm (1.6 and 2 inches). However, this also depends on which parts are being joined and the thickness of the boards.
- A screw that is too short won’t provide enough grip and can lead to instability because it may loosen easily.
- On the other hand, screws that are too long can penetrate through the backside of the material or even cause the edge material to split. This affects both the appearance and stability.
My tip: Make sure the screws are sized to penetrate at least two-thirds to three-quarters of the board thickness. For boards about 16 mm (0.6 inches) thick, that means screws of 40–50 mm (1.6–2 inches) in length. If you have particularly heavily loaded connections, choose the longer screws, but check that they are not too long.
Additionally, you should carefully drive the screws in with a suitable screwdriver to avoid cracking the material.
Conclusion: 4 x 50 mm (0.16 x 2 inches) chipboard screws are a good standard; also pay attention to the quality of the screws.
kaubi
5 Apr 2024 13:52
Hello Onrota,
I would like to go into more detail because the screw length, especially for furniture like IKEA Platsa, is not just about length but also the material and load.
First of all: The Platsa system is based on MDF and particleboard panels about 16 mm (0.6 inches) thick. The recommended screws are particleboard screws with a relatively fine thread profile to prevent splitting the panels.
- Screw length: A screw length of 40-50 mm (1.6-2 inches) is usually sufficient, as it provides enough grip in the panel without piercing through the other side. Depending on the type of connection, such as attaching back panels or feet, it can be useful to choose slightly longer screws, e.g., 55 mm (2.2 inches), if the screw is also driven into a component with more thickness.
- Screw diameter: A standard diameter of 4 mm (0.16 inches) (for example, 4 x 50 mm) is most common. Thicker screws increase holding power but carry a higher risk of splitting or cracking the panel.
- Material and thread: Particleboard screws are specifically designed for softer panels. They have a coarse thread that provides stable holding power without stressing the material too much.
- Sensitivities: Screws that are too short result in loose connections prone to wobbling. Screws that are too long can cause material damage or protrude, which is especially undesirable on visible edges.
- Screw type: For the Platsa system, you should not use regular wood screws. The coarse-threaded particleboard screws are more suitable.
Finally, I would like to know exactly which connection you need the screws for—that feedback helps to be more precise. Do you need screws for the main frame or for internal connectors?
I recommend paying attention to quality and driving the screws in slowly to avoid damaging the material.
O
Onrota
6 Apr 2024 08:15
kaubi schrieb:
Finally, I would like to know exactly which connection you need the screws for – a response would help to give more targeted advice. Do you need screws for the main framework or for the internal connectors?
Good question! I mainly need the screws for the connections between the individual modules of the main framework. The back panel will also be attached, but usually there are separate nails or thinner screws for that. Primarily, I want to secure the modules to each other, as the cabinets should form a large, connected unit.
I think the standard chipboard screws measuring 4x50 mm (0.16x2 inches) should be fine, but I wanted to be sure whether, for example, 55 mm (approximately 2.2 inches) screws would be a bit stronger, or if that would be unnecessary and possibly even risky due to piercing through.
draleo
6 Apr 2024 11:44
Onrota schrieb:
I think the standard chipboard screws with 4x50 mm (4x2 inches) are quite good, but I wanted to be sure whether 55 mm (2¼ inches) screws would be more stable or if that would be unnecessary and possibly even risky due to piercing through.
The risk of piercing through is definitely present with 55 mm (2¼ inches) screws if the panels are only 16 mm (⅝ inch) thick and the screw goes straight through one panel into the other. Normally, 50 mm (2 inches) is completely sufficient to achieve a secure hold in the material. Longer screws are only necessary if you’re fastening through thicker components or attaching additional materials.
Any extra stability from longer screws only results if the screw engages more material, but with panels of this thickness, that advantage is limited. Therefore, I recommend sticking with 4x50 mm (4x2 inches) screws for standard applications and checking that the screw does not damage the backside.
Additionally, you can use countersunk head screws to keep the surface neat.
