ᐅ What is the best way to clean the surfaces of PAX wardrobes?
Created on: 16 Jul 2022 08:37
Tardu
Tardu
16 Jul 2022 08:37
Some time ago, I purchased a PAX wardrobe from IKEA and have been very satisfied with its design and functionality so far. However, now it’s time to clean the wardrobe surfaces, and I want to make sure I do it correctly. Could someone from the community provide detailed advice on the best cleaning products and methods to gently but effectively clean the PAX surfaces? I’m especially interested in whether certain cleaners should be avoided to prevent damage such as scratches, discoloration, or a dull finish. Additionally, it would be helpful to know if there are specific cleaning requirements for the different surface types (such as high gloss, foil, or melamine). Many thanks in advance for the helpful tips!
FELOTAU
16 Jul 2022 09:12
Tardu schrieb:
Could someone from the community explain in detail which cleaning products and methods are best suited to gently but effectively clean the surfaces of the PAX wardrobe?
This is a really important question because, especially with high-quality furniture like the PAX wardrobe, I often feel unsure about whether cleaning products might cause damage. In my experience, a mild, pH-neutral all-purpose cleaner diluted heavily works well. This way, the wardrobe can be wiped gently. It’s important to use a soft, lint-free microfiber cloth.
For high-gloss surfaces, I’ve read that it’s better to avoid glass cleaners, as they often contain alcohol or ammonia, which can damage the finish. My advice is to use lukewarm water with a little dish soap instead, which is usually enough for dust and light dirt.
I admit I have experimented myself, and it’s really frustrating when cleaning leaves spots or dull areas. Perhaps other users could share if they recommend specific products or if they prefer home remedies like vinegar water?
Z
zarlu
16 Jul 2022 14:43
FELOTAU schrieb:
For high-gloss surfaces, I once read that it’s better to avoid glass cleaners because they often contain alcohol or ammonia, which can damage the finish.
I often find this kind of caution to be exaggerated. Honestly, how harmful can a glass cleaner really be if you’re not applying it full-strength every day? I think many people make too much of a big deal out of minor differences.
High-gloss surfaces are generally durable enough to handle common glass or multi-surface cleaners for short-term use. Of course, you should avoid abrasive sponges or harsh cleaning agents, but that’s where my concerns end. I’m not a fan of DIY cleaning remedies or vinegar for such special surfaces – those can even cause damage.
Sometimes I wonder if this is just a kind of modern cleaning frenzy: there’s no product that protects perfectly and universally all the time. What matters is using the cleaner correctly—don’t let it sit; instead, wipe it off quickly with a clean cloth.
flo-Theres
17 Jul 2022 10:21
zarlu schrieb:
I generally don’t recommend DIY home remedies or vinegar for such special surfaces – it can even cause damage.
I completely agree. Vinegar is generally not recommended for foil or melamine-coated surfaces because the acid can damage the surface texture and cause unwanted dulling over time.
The most important thing when cleaning PAX cabinets is to know the type of surface. Standard PAX cabinets are usually made of MDF with a melamine resin coating or are laminated. Mild cleaning agents without harsh chemicals are suitable for these.
My tips:
- For light dirt, simply use a soft, damp microfiber cloth
- For grease spots or heavier dirt, dissolve mild dish soap in water to dampen the cloth
- Avoid abrasive cleaners or harsh scrubbing pads
- For high-gloss surfaces, it’s better to use special care products designed for painted furniture that leave a protective film
If the cabinet gets dusty on top, regular wiping with a dry cloth is better than infrequent intense cleaning. This prevents scratches from dust particles during cleaning.
FELOTAU
18 Jul 2022 07:49
flo-Theres schrieb:
My tip:
- For grease stains or tougher dirt, dissolve mild dish soap in water to dampen the cloth
- Do not use abrasive cleaners or harsh sponges
- For high-gloss surfaces, it’s better to use specialized care products for lacquered furniture that leave a protective film
I think this is a very good summary! This gives everyone who is unsure a simple, risk-free guide.
What would also help me: How about drying? Should the surface be wiped dry immediately, or is air drying sufficient? I’m concerned that standing moisture, especially in joints, could eventually cause problems.
And what do you think about microfiber cloths with antistatic coating? Does anyone have experience whether they keep dust away better? I look forward to more tips and feedback!
