ᐅ What helps with squeaky cabinet hinges?
Created on: 1 Oct 2024 08:37
Ewaldla
Ewaldla
1 Oct 2024 08:37
Hello everyone, I have a problem with the hinges on my Ikea Billy bookshelves, which start to squeak unpleasantly after a while. The noise mainly occurs when opening or closing the doors. I’m wondering what exactly causes the squeaking and which methods or products have proven effective in permanently eliminating the sound. Are there specific lubricants, cleaning techniques, or adjustable settings on the hinges that might help? I would appreciate any practical and specific recommendations to make the squeaky hinge quiet again without damaging the mechanism or the wood.
Palenar
1 Oct 2024 09:04
Hello Ewaldla, squeaking in pivot hinges is indeed a common issue, usually caused by friction between metal parts or insufficient lubrication. First, you should check if the hinge has fine dirt or deposits that might interfere with its movement. I recommend starting with a thorough cleaning using a lint-free cloth and possibly some isopropyl alcohol to remove grease and dirt residues.
After that, applying an appropriate lubricant is crucial. You can use silicone or PTFE sprays designed specifically for metal joints, as they do not harden or attract dust. It is important not to just use any oil, as these often dry out quickly or become sticky.
Also, it’s worth checking whether the hinge screws might be loose; gently tightening them can prevent movement problems that increase squeaking. If you could tell me exactly which model is installed and how long the shelves have been in use, I can provide more specific advice.
Ewaldla schrieb:
was genau die Ursache für das Quietschen ist und welche Mittel oder Methoden sich bewährt haben
The cause is often a combination of mechanical wear and poor maintenance, so regular cleaning and lubrication is advisable.
lyndon
1 Oct 2024 14:19
As a supplement to Palenar’s detailed post, I would like to highlight a few points: Many people use WD-40 or oils from the garage, but these are only effective for a short time and can attract dust magnetically, which makes the problem worse. For furniture and hinges, specialized dry lubricants based on silicone or PTFE are better suited because they stay in place longer and do not promote contamination.
Additionally, if possible, the hinge can be gently removed and completely disassembled in order to thoroughly clean all moving parts and then re-lubricate them. This is justified especially with heavy use, since older hinges can suffer from abrasive wear on the material itself and may need to be replaced.
Perhaps a tip: Even though ‘Billy’ uses relatively simple hinges, their function should be checked regularly, as faulty adjustments can cause not only squeaking but also long-term damage to the furniture.
lisku
2 Oct 2024 07:52
For quickly eliminating squeaking, I recommend spraying a thin layer of silicone spray on the hinge and opening and closing it several times. This usually works immediately and is clean to use. Avoid oil, as it can become sticky and attract dust.
klo61
3 Oct 2024 12:27
Hello everyone, I would like to add some practical tips to the discussion. Especially with Billy hinges, it is important to ensure that the hinge itself is not damaged or bent, as mechanical deformations cause constant creaking and squeaking despite lubrication.
First, check if the screws are tight – sometimes they loosen due to movement. Then carefully clean the hinge with a cloth, as Palenar and lyndon have already recommended. Important: Do not use water, as it can cause rust.
For lubrication: I personally prefer using a spray with PTFE since it effectively seals the friction surfaces and lasts a long time. After applying, you should move the hinge several times to distribute the lubricant evenly.
Finally: You can also slightly widen the gap with a small wooden or plastic wedge to create more play in the hinge – if the tension is too high and causing the creaking.
Palenar schrieb:
dass die Schrauben der Scharniere vielleicht zu locker sind
I can only confirm this, as this is often the problem, especially with heavily used shelves.
If none of this helps, the hinges are also inexpensive to replace. This is often the most sustainable solution when they already show signs of wear.
I hope these tips help everyone struggling with squeaking Billy hinges!
