ᐅ How can creaking be prevented in BILLY hinges?
Created on: 3 Oct 2023 09:07
rickdan
rickdan
3 Oct 2023 09:07
I have noticed a faint creaking noise coming from the hinges of my IKEA Billy bookshelf, which occurs repeatedly when using the doors. My specific question is: how can this creaking on Billy hinges be effectively prevented or eliminated?
I have already tried adjusting the hinges, as I suspected that a misalignment might be causing the problem. Unfortunately, this did not have the desired effect. The noise occurs regardless of the door position – both when opening and closing.
Does anyone know the exact cause of this creaking in Billy systems? What products or methods do you recommend to make the hinges silent without making the mechanism stiff?
Thanks in advance for your experiences and tips!
Goixkin
3 Oct 2023 09:23
The creaking usually comes from a lack of lubrication. Simply apply some silicone oil or graphite spray to the hinge pins. This usually helps.
Lotizar
3 Oct 2023 09:45
The creaking in BILLY hinges is mainly caused by friction between metal components that are not sufficiently lubricated during use. Since IKEA generally uses simple, low-maintenance designs for BILLY hinges, a targeted cleaning followed by lubrication should be done first.
A thin, non-sticky lubricant is recommended, such as silicone spray or a special furniture care product. Mineral oil-based oils can attract dust and promote dirt buildup over time, which is counterproductive.
Before applying lubricant, it is advisable to clean the hinges with a dry cloth and operate the moving parts several times to loosen any deposits. After lubrication, the doors should be opened and closed several times to evenly distribute the lubricant.
GOLO42
3 Oct 2023 10:12
I would like to explain the issue in more detail, as squeaking is often caused by multiple factors:
1. Mechanical adjustment: First, it must be ensured that the hinges are installed and aligned correctly. Even slight tension from misaligned mounting can create friction points that cause squeaking.
2. Material fatigue and wear: Hinges are often made of die-cast or stamped metal with plastic coatings. Over time, worn bearing surfaces can lead to irregular movements and noises.
3. Lubricant: As already mentioned, the right lubricant is essential. It is recommended to use non-sticky substances such as silicone or PTFE spray. Other greases or oils may harden or attract dust.
4. Environmental conditions: Humidity and temperature fluctuations affect material behavior and friction.
Step-by-step solution proposal:
- Check screws and tighten if necessary;
- Open and close hinges slightly to detect resistance points;
- Remove old lubrication with a solvent (isopropanol) and let it dry;
- Apply silicone spray precisely to the pivots and contact surfaces;
- Move the hinges repeatedly to distribute the lubricant.
If this does not help, it may be due to worn parts that need to be replaced.
Question: Are you using special accessory hinges or the standard versions from IKEA?
rickdan
3 Oct 2023 10:34
I am only using the original BILLY standard hinges. The shelf is 4 years old and has been used normally. Thanks for the detailed explanation!
I will try your instructions for cleaning and lubricating.
My suspicion is also that the mechanism might be a bit dirty or could use some lubrication.
Besides silicone spray, are there other products currently recommended elsewhere, such as special PTFE? That sometimes has a stronger smell, right?
fiman
3 Oct 2023 10:48
Silicone spray is usually the first choice because of its low odor and non-sticky properties. PTFE (Teflon) provides an even better lubricating film but does have a somewhat stronger smell, especially when solvents are involved.
For furniture like BILLY, silicone is recommended because it does not attract dust and stays clean longer.
