Hello everyone, I am planning to use several Billy bookcases from Ikea for a larger storage project. However, I am unsure which models are specifically designed to support heavy loads. I am interested in the maximum load capacities of the different versions (standard, reinforced, wider variants, etc.) and whether anyone can share their experience regarding how stable these shelves are in everyday use with higher loads. Any advice on additional reinforcements or suitable shelving boards if the originals are not sufficient would also be greatly appreciated. Thank you in advance!
Are there any specific recommendations on where I can buy or have custom-made stronger shelves in the right size? Also, do you have any tips on how to properly install the reinforcements to actually increase the load capacity without drastically changing the appearance of the shelves?
PeoDaniel10 Jan 2023 17:19For stronger shelves, you can have plywood boards cut to size at hardware stores or specialist timber retailers. Plywood is sturdy, hardly flexes, and is ideal as a shelf board.
When reinforcing, metal brackets under the shelves are very effective, as they reduce bending stress. Make sure the brackets are placed at the front and back edges of the shelf. Secure them firmly to both the shelf and the frame with wood or metal screws.
You can influence the appearance using acrylic paint or wood veneer to match the Billy shelves. Easy installation, high stability.
PeoDaniel schrieb:
Have plywood sheets cut to the required dimensions at hardware stores or timber suppliers That sounds great, thank you!PeoDaniel schrieb:
Metal brackets under the shelves are very effective How durable are they with frequent loading and unloading? Don’t the screws come loose after some time?M
Marlenepa11 Jan 2023 08:22That is a valid question. It is important to tighten the screws firmly and use high-quality particle board screws designed specifically for wood.
Regular retightening after the first few weeks is advisable to ensure stability. If accessible, you can also use small drive-in anchors to prevent the screws from loosening easily.
Alternatively, you can apply wood glue at the contact points, which adds extra strength once it cures.
