Hello everyone, I am planning to use several Billy bookcases from Ikea for a larger storage project. However, I am unsure which models are specifically designed to support heavy loads. I am interested in the maximum load capacities of the different versions (standard, reinforced, wider variants, etc.) and whether anyone can share their experience regarding how stable these shelves are in everyday use with higher loads. Any advice on additional reinforcements or suitable shelving boards if the originals are not sufficient would also be greatly appreciated. Thank you in advance!
Standard Billy shelves usually support about 12-15 kg (26-33 lbs) per shelf. There are no official "reinforced" models for heavier loads, but you can upgrade to stronger shelves. Wider versions often do not have a higher load capacity but are more stable due to the larger surface area.
To answer your question precisely, it is important to distinguish between the different shelves and their material thicknesses in Billy bookcases. The classic Billy is designed for light to medium loads, typically around 30 kg (66 lbs) per shelf, provided the weight is evenly distributed. However, the thinner particleboard shelves are prone to bending under point loads.
There are wider versions with sturdier side panels that can support more weight thanks to additional support braces. If you plan to store heavy items, it may be worth considering replacing the shelves with stronger versions made from plywood or even metal. Installing metal brackets to reinforce the shelves can also significantly improve their load-bearing capacity.
One more question: How much weight per shelf are you specifically planning? This will help provide the right recommendations.
Thank you for the advice! I want to load shelves with weights of up to 40 kg (88 lbs), mainly tools and heavier boxes. Therefore, it is important for me to know whether the classic Billy shelves can safely support this load or if I should start looking for alternative solutions. I also plan to mount the shelves side by side on the wall in some cases.
Since you aim for loads of up to 40 kg (88 lbs) per shelf, some details need to be considered:
1. Original Billy shelves are not designed for these loads, especially the thin particleboard shelf is the weakest point. The standard maximum load is about 15-20 kg (33-44 lbs) per shelf.
2. Alternatively, you should use shelves made of solid wood or plywood of the same size, which can carry significantly more weight.
3. Wall mounting is mandatory for heavy loads and greatly increases stability.
4. If necessary, shelves can be reinforced from the outside with additional beams or profiles.
5. I recommend conducting a load test in advance, if possible.
Important: The shelf construction itself and the wall attachment play a major role in overall safety.
Surela schrieb:
Original Billy shelves are not designed for these loads Exactly, when the loads are that high, the shelves themselves become the weak point.kulau schrieb:
There are wider versions with sturdier side panels That doesn’t make much difference if the shelves themselves are too thin.Similar topics
