ᐅ How can I protect BILLY shelves from warping caused by moisture?
Created on: 1 Nov 2022 08:17
nokauHello everyone,
I have a question that’s been on my mind lately: How can I effectively protect my IKEA Billy bookcases from warping due to moisture?
I have several of these shelves in my home office, and I’ve noticed that the humidity level there can sometimes be a bit higher, especially during winter. The back panels and side panels of the shelves are starting to warp or ripple slowly, which obviously doesn’t look great and could also affect stability.
I’m particularly interested in what measures you would recommend to prevent this. Are simple solutions like dehumidifiers or special protective coatings enough? Or are there proven tricks to protect the material without compromising the design or functionality?
What experience do you have with indoor environments that have moderate to slightly high humidity levels?
Looking forward to your tips, recommendations, and honest feedback! Thanks in advance.
baAlejandr1 Nov 2022 08:42Hello nokau,
First of all, I find your question very clearly formulated, which makes it easier to answer.
BILLY shelves are made of laminated particleboard, which unfortunately is sensitive to moisture because the surface is only lacquered or foil-covered and does not offer true water resistance.
For protection, I recommend:
1. Using a dehumidifier to effectively regulate the indoor humidity.
2. Decoupling shelves mounted directly on the wall with spacers so that moisture cannot penetrate the back panel due to insufficient ventilation.
3. Treating the wood before installation with special impregnating agents or clear varnish that repel moisture without significantly altering the appearance.
4. If possible, avoiding installing shelves on exterior walls or checking the wall moisture beforehand.
It is important to allow treated surfaces to dry thoroughly before putting any weight on the shelves again.
I hope this helps you already.
Hello nokau,
I would like to provide you with a brief guide on how to systematically protect your BILLY shelves from moisture:
1. Measure humidity: If you don’t have a hygrometer, get one. The ideal indoor relative humidity is between 40-60%, especially in winter.
2. Ensure ventilation: Position the shelves so that air can circulate, which helps prevent moisture buildup.
3. Distance from the wall: A small air gap of a few centimeters (inches) helps prevent moisture transfer from the wall.
4. Surface treatment: Clear varnishes or sealants are suitable to seal the particleboard and significantly reduce water absorption.
5. Use a dehumidifier: An automatic dehumidifier in areas with high humidity can prevent problems at the source.
6. Regular inspection: Check regularly for early signs of changes to respond in time.
Common mistakes include placing shelves directly against cold exterior walls without any gap or using unsuitable paints/coatings that trap moisture instead of repelling it.
Good luck with implementing this!
Jensson schrieb:
The optimal indoor relative humidity is between 40-60%, especially in winter.That is correct. Additionally, I would like to point out that the BILLY shelves are typically made of particleboard with a melamine coating. This material combination is not waterproof and will swell significantly if exposed to prolonged moisture.
I recommend treating the shelves before installation with a permanently elastic, clear wood preservative stain, specifically suitable for assembled furniture. Make sure to seal all sides, including the cut edges of the particleboard, as these are particularly absorbent.
Also, using plastic or rubber underlay mats can help isolate the shelves from direct contact with cold or damp floors.
In short: minimizing sources of moisture and fully sealing the furniture are the most effective measures.
Hello nokau,
I can confirm the previous advice and would like to provide a complete overview:
Moisture mainly causes deformation because particleboard absorbs moisture and swells.
Best practices:
- Do not place the shelf in damp rooms or near water sources
- If unavoidable, use a dehumidifier
- Treat all surfaces with appropriate varnish or wood preservative at least twice, including edges and the back
- Avoid direct contact with walls to allow for air circulation
- If possible, use additional shelf dividers made of metal or glass, which are less susceptible to moisture
I have personal experience with BILLY in a basement office; thanks to a combination of clear varnish and continuous use of a dehumidifier, the shelf stayed in good shape for a long time.
I would be interested to know the exact humidity level where you are.
Best practices:
