ᐅ What can I do if the assembly of the Brimnes unit from IKEA is stalled?
Created on: 29 Sep 2023 19:23
Liroso
Liroso
29 Sep 2023 19:23
Hello everyone, I ordered the IKEA Brimnes shelving unit and tried to start assembling it yesterday and today. However, I’m running into some difficulties, especially when attaching the side panels to the base plates. The instructions are clear, but some screws don’t seem to fit properly or are very hard to screw in, which makes me worried that the material might get damaged if I continue. Are there any proven tips or tricks for assembling the Brimnes safely and efficiently? I’ve already tried carefully pre-drilling the screw holes and lubricating them slightly with some WD-40, but this didn’t help much. Also, I’m wondering if it might make sense to complete the steps in a different order to make assembly easier. I’m grateful for any advice, especially from anyone who has experience with the typical problem areas of the Brimnes.
fredle
29 Sep 2023 20:07
Hello Liroso,
I’m familiar with the Brimnes and would like to suggest a structured approach that always helps me:
- Step 1: Sort the components and carefully check them for any damage. With the Brimnes, some factory-drilled holes can be slightly misaligned. If the screws catch, don’t force them, as this can damage the wood.
- Step 2: Completely inspect all screws and dowels – parts from other models often get mixed in, which can cause fitting issues.
- Step 3: Make sure to follow the instructions exactly and in the specified order. For the Brimnes, the sequence of assembling the side panels is important, as otherwise tensions may occur.
- Step 4: Insert screws at a slight angle and only fully tighten them once all screws for that part are in place. This prevents warping.
- Tip: If you have trouble screwing in the screws, a small drop of lubricant can help, but use WD-40 sparingly, as it can affect the wood.
- If you encounter strong resistance, first slightly widen the pilot holes with a thin drill bit, removing only a minimal amount of material carefully.
I hope this helps. If you want, feel free to mention the exact point where you’re stuck – often there are specific tips for those situations.
noge58
29 Sep 2023 22:51
fredle schrieb:
With the Brimnes, the order of assembling the side panels is important to avoid stresses.
Absolutely right! I assembled the Brimnes last year and can confirm that carefully following the assembly steps really makes the difference! Remember, don’t give up – sometimes it just takes a bit of patience and attention to detail, and then the shelf will be rock solid! 👍
Also: If you notice a screw doesn’t fit, don’t immediately use force! Instead, try repositioning the screw or double-check whether the correct anchor is being used. I had that issue with the back panels back then. Just don’t get discouraged, it’s worth it!
You’ve got this! 🙂
Gafiel
30 Sep 2023 06:38
Good morning, Liroso,
to help you effectively, I’m curious if you’ve already checked the type of screws and dowels that IKEA supplies with the Brimnes, or if you’re only using original parts? Sometimes these sets include lower-quality screws whose threads don’t fit perfectly, which can make screwing more difficult.
Another important point is the type of tool you’re using: a cordless screwdriver with torque control makes the job much easier because you can tighten the screws carefully. If you’re only working with hand tools, it naturally requires more strength and patience.
Regarding the sequence: the instructions generally recommend a sensible order, but especially for the Brimnes, I suggest keeping the following points in mind:
- Avoid fully aligning and tightening the side panels right away. First, insert all screws gently so the parts still have some play.
- The back panel should be fitted tightly at the end to stabilize the structure without causing any pre-stressed deformation.
One more tip: if the wood swells around the drilled holes (moisture in the wood can occur when unpacking), I recommend airing the wood briefly in a warm, dry place before continuing assembly.
Feel free to let me know exactly where you’re having trouble, and I’ll help you with more detailed advice.
PeoDaniel
1 Oct 2023 13:44
noge58 schrieb:
Absolutely right! I assembled the Brimnes last year and can confirm that precisely following the assembly steps makes all the difference!
I fully agree. For the Brimnes, I also recommend the following:
- Work on a stable, level surface. Uneven bases quickly lead to fitting issues.
- Before installing the shelves, check that all grooves fit properly, as some can be quite tight.
- Use a rubber mallet when inserting wooden dowels to avoid damaging the material.
If something doesn’t seem to fit as it should, take a moment to pause. Sometimes stepping away for a few minutes helps to return with fresh eyes.
If you notice screws not going in straight, also check whether the holes were factory-made and not slightly misaligned due to production variations. In that case, carefully re-drilling or readjusting is the only solution.
In my opinion, the Brimnes is quite sturdy if you take the assembly seriously—better to invest time than to apply pressure. Good luck with your build!
