ᐅ Marks on KALLAX caused by cleaning products – how to remove them?
Created on: 5 Jan 2016 19:47
Pisau
Pisau
5 Jan 2016 19:47
While cleaning my KALLAX shelf, I noticed that some cleaning agents left unsightly streaks on the surface. The marks don’t seem to be just superficial; they almost look like light discoloration or surface damage.
I usually use common all-purpose cleaners or vinegar water, always carefully with soft cloths. Still, these streaks remain, especially when I dry the shelf. Has anyone experienced this problem?
How can I best remove these streaks from my KALLAX without damaging the surface? Are there any specific cleaning products or techniques that have proven effective? Or should I consider switching to entirely different cleaning methods?
I would appreciate any tips or advice!
SIAURORA
5 Jan 2016 20:35
Interesting post.
Pisau schrieb:
The stains don’t seem to be just on the surface; they almost look like slight discoloration or surface damage.
It sounds almost as if the cleaning agent has affected the laminate or coating. Many people rely too heavily on aggressive cleaners, which is usually counterproductive.
Wouldn’t it be better to use only a small amount of water and very mild cleaners from the start, and reconsider the choice of the KALLAX?
In my opinion, the issue lies not only with cleaning but also with product selection and handling. So why not use specialized furniture cleaners designed specifically for painted or laminated surfaces? This helps prevent long-term damage.
Kabau
5 Jan 2016 21:22
Streaks often appear when residue from cleaners is not completely removed.
It is best to wipe again with clear water and then polish dry.
I would generally not recommend using vinegar water on furniture.
PRA64
6 Jan 2016 07:13
Allow me to briefly add a few steps from my experience with IKEA furniture and laminate surfaces:
1. First, wipe the furniture with a slightly damp microfiber cloth, without any cleaning agents.
2. If there are cleaning residues, dilute a mild dish soap in water and wipe with that.
3. Vinegar water can damage the protective layer on laminate and melamine-coated surfaces—better to avoid it.
4. After cleaning, be sure to wipe again with plain water to remove any residue.
5. Use a soft, lint-free cloth or polishing cloth for drying.
If streaking is already present, sometimes a special laminate polish can help by filling in tiny micro-scratches and smoothing the surface.
Not all stains can be removed by cleaning; sometimes visible damage can only be repaired by replacement or refinishing.
dusujan
6 Jan 2016 08:37
I can understand your situation well; it’s really frustrating when surfaces no longer look as good as they used to.
I would recommend starting by thoroughly wiping the surface with clear water, then testing a mild polish or wax-based furniture care product on a hidden spot. This has often helped me to restore shine and reduce streaks.
But be careful and try it somewhere else first to make sure the surface doesn’t get damaged.
Don’t worry, this happens to many people and usually there’s a solution – just take it step by step 🙂
SIAURORA
7 Jan 2016 13:51
Kabau schrieb:
I wouldn’t recommend vinegar water for furniture.
I fully agree, vinegar on melamine is an absolute no-go.
PRA64 schrieb:
Vinegar water can damage the protective layer on laminate and melamine surfaces – better to avoid it.
That’s exactly what I mean.
Interestingly, some suppliers claim that baking soda or caustic soda can help remove stains. I consider this risky since alkaline substances can damage the surface.
My advice: instead of harsh chemicals, use specially formulated laminate cleaners. The market offers several environmentally friendly and surface-safe products. Also, there are drying tips: for example, using a slightly damp cloth instead of wiping completely dry right away reduces streaks.
So, caring properly for your furniture is really important here—not just cleaning briefly, but protecting it in the long term.
