ᐅ Best method to cover a Kallax unit with adhesive film?
Created on: 23 Oct 2017 18:37
mubacary
I am planning to cover my IKEA Kallax shelf with adhesive film to enhance its appearance and protect it from wear. Since this is a very popular and versatile shelving unit, choosing the right application method and type of film is not straightforward. My question is:
In your experience, what is the best method to apply film to a Kallax shelf to ensure the film adheres smoothly without bubbles, sticks well, and remains durable? What type of film do you use (e.g., self-adhesive vinyl film, contact paper, or specialized furniture film), what preparatory steps should be taken (e.g., cleaning, sanding), and are there any tips for successfully covering sharp corners or edges?
I look forward to your advice and experiences!
TEKIN
23 Oct 2017 21:43
RonJarrett schrieb:
Wet application method using a water-detergent mixture allows for positioning the film and avoiding air bubbles.
This is the most effective method. Additionally, I recommend closely monitoring the temperature when working with matte films. Excessive heat can damage the adhesive surface or deform the film.
Furthermore, caution is advised when working on painted Kallax fronts: sanding too aggressively can damage the surface, so always use light pressure and very fine-grit sandpaper.
For maximum adhesion, it is best to choose film brands with advanced adhesive technology, such as 3M DI-NOC or Oracal series, which are specifically designed for furniture films.
mubacary
23 Oct 2017 22:08
Thank you for the really helpful contributions so far; they have given me many new perspectives!
One more question: How significant is the advantage of the wet application method compared to dry sticking? Is it suitable for small areas or individual Kallax compartments as well, or is it more appropriate for large surfaces?
Also, does anyone have recommendations for specific films that are durable against scratches and moisture in everyday use but are not too difficult to apply? I plan to use the shelf primarily in the living room, where it will only occasionally need wiping and will be exposed to some dust.
Thanks in advance!
Garth49
24 Oct 2017 09:11
Hey mubacary,
great question! I wanted to highlight the importance of using high-quality vinyl films: premium vinyl is much more tear-resistant and causes fewer issues during installation. Also, I find that wet application makes a lot of sense for all surfaces—even small sections—because it helps prevent air bubbles and blisters.
A little tip: keep a spray bottle with soapy water handy, as it makes it much easier to position the film precisely.
Another thing not to underestimate: you should always carefully consider whether to apply the film over the entire surface at once or cut it into more manageable sections—this makes handling much easier!
Have fun working on your project! 🙂
maflo
24 Oct 2017 10:34
For everyone who likes to follow a small how-to, here is a step-by-step guide on how I applied adhesive film to my Kallax:
1. Preparation:
- Empty the shelf and degrease the surface with a mild cleaner.
- For painted surfaces, gently sand with 320-grit sandpaper.
2. Cutting:
- Cut the film slightly larger than the area to be covered so you can easily work on the edges later.
3. Wet application:
- Mixing ratio: about 1 liter (1 quart) of water + a few drops of dish soap in a spray bottle.
- Generously spray the surface.
- Mark the back side of the film to help with peeling it off.
- Place the film onto the wet surface, then position and align it.
4. Smoothing:
- Use a squeegee (preferably with a felt edge) to push air bubbles out from the center toward the edges.
5. Edges & corners:
- Carefully cut the film at the corners, warm it with a heat gun, and gently fold it around the edge.
6. Final phase:
- Dab off excess water with cloths.
- Let it dry for at least 24 hours.
This method guarantees a clean result – with a bit of patience, it works really well!
theo63
24 Oct 2017 11:22
The wet application method offers the benefit of being able to reposition and adjust the film during installation. This greatly reduces air bubbles and uneven adhesion, especially on larger surfaces or smooth materials like those used in Kallax. In contrast, dry sticking causes the film to adhere immediately, often resulting in wrinkles and bubbles.
In my opinion, wet application is almost always preferable, except for very small, simple surfaces where precise work is possible and there are few edges to overcome.
Meonu
24 Oct 2017 13:03
Franz schrieb:
What helped me was making small cuts in the corners with scissors, so the film can be folded more easily and laid neatly around the corners.
That’s a great tip! That’s exactly how I did it as well. I would definitely recommend this to anyone having trouble with the corners when applying the film.
And one more thing: patience is really key! Don’t install the film under time pressure. It’s better to take a moment to hold your breath than to create a bad crease. 😉
