ᐅ My KALLAX unit completely fell apart after flooding – is it possible to save it?
Created on: 25 Mar 2023 09:12
dofa46
Hello everyone, I hope someone here can help me. My KALLAX unit from Ikea was completely swollen after the recent flood in my basement and has practically disintegrated into separate, barely connected layers. The surface feels spongy, the corners are crumbling, and the wood fiber has become completely unstable. Originally, I hoped to save the furniture with drying or repair measures, but I lack experience with how this material reacts to such moisture and whether there are any practical ways to make a disintegrated unit usable again. Has anyone had a similar experience or can provide concrete advice? I am especially interested in whether treatment with special wood preservatives, glue, or certain drying methods still makes sense, or if I should just dispose of it.
dofa46 schrieb:
Would it still be worth trying special wood consolidants? Or is the material deterioration already too advanced?I once had a similarly water-damaged piece of furniture and initially treated it with a wood consolidant in hopes of saving it. Unfortunately, it only helped minimally because the cell structure was too badly damaged. So, I agree with you—the chances of saving the module with a wood consolidant are quite low.
My advice is to preserve the surfaces if possible for decorative purposes and otherwise reuse the material for a new piece of furniture. See this as a fresh start, and maybe you can choose a more water-resistant solution this time. 🙂
dofa46 schrieb:
The module was standing in knee-high water for about 3 days, followed by several weeks of extremely high humidity in the basement.Regarding this timeline: standing in water for 3 days is practically fatal for particle board or plywood. Capillary action draws a large amount of water into the fiberboard. The subsequent high humidity prevents rapid surface drying, which further weakens the microscopic bonds.
Special wood consolidants are sometimes liquid synthetic resins or deep impregnations, usually applied to load-bearing wood structures. In your case, however, the structure has mostly broken down and become porous. There is practically no load-bearing capacity left to absorb or properly bond with consolidants.
My advice: if you are willing to experiment, you could try using epoxy resin on small areas to achieve at least localized stability – but this is labor-intensive and not suitable for large surfaces.
Otherwise, I would consider the module lost and recommend replacing it with a new one. You might still be able to use the melamine surfaces separately as decorative elements.
Dilen schrieb:
Special wood stabilizers are sometimes liquid synthetic resins or deep impregnations, usually applied to load-bearing wood structures.I completely agree. This is an important point that is often overlooked – stabilizers require an intact material into which they can penetrate and cure. From a cost-benefit perspective, extensive repairs on severely damaged chipboard are generally not worthwhile.
In this case, I would definitely recommend replacement, especially since KALLAX has a modular design that allows relatively easy swapping of entire components.
Hey dofa46, I really like your detailed question, it’s helpful for everyone here! 🙂
I also once had water damage to my furniture, and of course, that’s really frustrating! But sometimes it’s better to leave the debris behind and start fresh – especially with furniture made from particleboard that has absorbed so much water.
Maybe you can use the KALLAX as a small upcycling project? A bit of sanding, new paint, some cool decorative elements – that’s how I ended up with a great new dresser!
Hang in there, sometimes these setbacks lead to really cool new things that are even better than before 😉
