ᐅ The Kallax shelf in the hallway always tips toward the entrance – any advice?
Created on: 8 Aug 2023 08:42
Noemibar48
I have a somewhat unusual problem: In our hallway, there is an Ikea Kallax shelf that we use as a shoe rack. Unfortunately, the shelf keeps tipping slightly toward the entrance door. It’s not a huge issue, but it’s annoying, and I’m worried it might get damaged or eventually fall over.
The shelf stands on a relatively smooth laminate floor, and I suspect that the weight of the shoes combined with the uneven surface causes it to lean toward the entrance.
Does anyone have practical tips or experience on how to make the Kallax more stable so it no longer tips? Maybe there are special pads, anchors, or weight distribution tricks that could help. I’m grateful for any advice!
Danial
9 Aug 2023 07:48
daalessio schrieb:
fix the shelf to the wall using wooden dowels or an angle bracket
That certainly makes sense, but the question is whether the Kallax would still remain flexible. Sometimes the exact problem is that fastening from the back is difficult, especially if no wall mounts can be installed (e.g., tile backsplash or fragile walls).
How stable is the laminate floor? In theory, could you use a flat weight (such as a glass plate or wooden board) placed under the shelf to reduce the risk of tipping without stressing the wall?
I think the idea of shifting weight to the bottom is basically sensible, but I wonder how effective it really is if the floor is not completely level.
Matthewt48
9 Aug 2023 09:01
I’m happy to help with hallway furniture issues. Kallax often tips over if the floor surface is uneven or sloped. Laminate flooring often limits the options for securing furniture.
A proven method is to use small furniture shims made of cork or plastic that you can place under individual feet to perfectly level the shelf.
I also recommend a non-slip rubber mat under the shelf. This not only prevents sliding but also helps to distribute the weight better on laminate flooring.
If the shelf still wobbles, you should check the weight distribution: shoes vary in size, and loosely arranged shoes can reduce stability.
Noemibar48, have you tried positioning the shelf without any contents first and then slowly adding items? Sometimes that helps to optimize the center of gravity.
Noemibar48
9 Aug 2023 12:29
Thanks for the helpful tips so far!
@kaubi The number of shoes is about 10 pairs, of which 7 are sturdy boots and 3 are lighter sneakers. Most of the boots are placed on the upper shelves because the lower ones are full of other items –
Matthewt48 schrieb:
Noemibar48, have you tried positioning the shelf without any contents first and then gradually filling it?
That sounds like a good idea, I’ll give it a try.
I like the idea of securing it to the wall, but the hallway is rented, and I don’t want to make holes in the wall.
@Danial The option with distributing the weight evenly under the shelf might work for us. I have some space underneath the shelf and could place a sturdy board or a thin metal plate.
If anyone can recommend specific non-slip mats or furniture wedges, I’d really appreciate it.
Best regards!
andre3
9 Aug 2023 15:14
Noemibar48 schrieb:
If anyone can specifically recommend suitable anti-slip mats or furniture wedges
Regarding anti-slip mats: You can find mats made of Sorbothane or rubber with a textured surface at hardware stores or online, which can also be cut to size. Specifically, “furniture anti-slip mats” are available under names like “SorboStop” or “self-adhesive anti-slip mats.” These can increase friction on laminate flooring.
For furniture wedges, I recommend adjustable-height plastic wedges, for example from manufacturers like “Famo” or “Hettich.” These are easy to adjust and take up little space.
It is important to adjust the wedges so that all shelf legs rest securely, which can be checked using a spirit level.
Since wall mounting is not desired, the combination of a sliding-support base and targeted weight distribution remains the best solution.
Aimee
10 Aug 2023 08:26
Rubber furniture wedges are a good choice.
They also help prevent damage to laminate flooring.
Non-slip mats made from one-sided studded material are available from "Tesa" and "Fellowes" and work well.
Noemibar48
10 Aug 2023 18:37
Update from my side:
I have now completely emptied the shelf and carefully adjusted the feet using rubber furniture wedges that I found at the hardware store. Then, I placed a non-slip mat underneath, as recommended by several people.
After that, I stored the heavy shoes in the lower compartments, and as a result, the Kallax now stands much more stable and barely tips over.
kaubi schrieb:
Redistribute weight load: Heavy shoes or other items should be placed in the bottom compartments whenever possible
This really proved effective and was a key factor!
Many thanks to everyone for the valuable tips, I’m relieved 🙂
