ᐅ Who uses Kallax as a permanent wardrobe in the hallway – is the stability sufficient?
Created on: 24 Jan 2021 07:12
talhapra
talhapra
24 Jan 2021 07:12
Hello everyone, I have been considering for some time whether to install the Ikea Kallax shelf as a permanent wardrobe solution in my hallway. I am especially interested in how stable and durable the shelf really is in daily use when it is used for hanging jackets, storing shoes, and possibly also for bags. Does anyone here use the Kallax as a fixed wardrobe solution in the hallway and can share insights about its stability? I want to avoid it wobbling or sagging after a short time—especially since we often wear larger jackets or heavy coats. I look forward to hearing about experiences, tips, and any cautionary tales so I can better assess whether the Kallax is truly suitable for permanent use in this way.
fepau
24 Jan 2021 08:35
Great question! 🙂 I have been using my Kallax as a hallway wardrobe for over 2 years now and I’m really impressed! The shelf is extremely sturdy when properly secured to the wall. I also added some baskets for gloves and hats, and hooks above for jackets. Of course, it’s not specifically designed as a wardrobe piece, but with a bit of DIY, it looks really good! Remember: wall mounting is essential, otherwise it can easily tip over. Good luck!
Traman4
24 Jan 2021 09:02
Using Kallax as a coat rack works well when it is securely fixed to the wall. Shoes or jackets are no problem. Do not exceed the load capacity.
PULAU
24 Jan 2021 10:16
I briefly tested the Kallax myself as a coat rack and can confirm that its load capacity is adequate as long as the furniture is properly secured. It becomes problematic mainly with constant heavy use or when hanging many heavy coats. It is also advisable not to use the internal shelves for very heavy items to avoid warping the material.
bupar
24 Jan 2021 12:44
From a technical perspective: Kallax shelves are made of particleboard with a melamine coating, which provides decent basic stability. According to the manufacturer, the maximum load per compartment is about 13 kg (29 lbs), but regularly hanging heavy coats as a transverse load is critical. Wall mounting is essential to prevent tipping and twisting. For permanent use, additional reinforcement may be advisable, for example with metal brackets or back panels with secure fixing.
lorena
25 Jan 2021 07:29
From a technical perspective, I can add a few points: The Kallax is often underestimated in its function as hallway furniture. Its stability largely depends on the installation, where the wall type must be taken into account, for example, concrete versus drywall panels. The latter require special anchors and possibly rail fittings to ensure sufficient load capacity. The weight of the items stored there should also be considered. For heavier coats and bags, it is advisable not to rely solely on the shelves but to additionally install sturdy wall hooks or even a rail above the Kallax to better distribute the load. Is your hallway rather small or large, what type of wall do you have, and how many people use the wardrobe? These details would help refine the assessment.
