ᐅ Securing KALLAX with anti-slip pads – are there suitable options available?
Created on: 17 Jan 2020 08:17
keplo
I have a KALLAX shelf unit from IKEA and would like to secure it better against slipping, especially on smooth floors like laminate or tile. My main concern is preventing it from tipping over, as the unit is quite tall and may occasionally hold some weight.
So my question to the community is: Are there any specific anti-slip pads that fit well under KALLAX shelves? Important factors for me are size, adhesive strength, and whether they can be removed cleanly without leaving residue.
So far, I have only found general anti-slip pads online, none specifically sized for KALLAX or that are larger or custom-fit. Are there any recommended products or tips for secure attachment?
Thanks for your detailed opinions and experiences!
keplo
17 Jan 2020 10:45
RABLA schrieb:
Just stick four thick rubber feet under the corners.
Which rubber feet exactly do you mean? Are the small ones often used for chairs sufficient, or do you have specific pads in mind?
It is also important to me that they are not very noticeable – ideally, a discreet solution that does not visually interfere or add bulk.
gauvin37
17 Jan 2020 11:10
I recently cut solvent-free non-slip rubber sheets to size myself and placed them under my shelving unit. They come in different thicknesses (3-5 mm (0.12-0.2 inches)) and are almost invisible if you choose a dark color.
They hold very well, are durable, and can be removed without leaving any residue.
They are often cheaper than individual pads. You might want to look up “cutting your own non-slip rubber mats.”
klo40
18 Jan 2020 07:35
here is a brief guide in case anyone is still unsure:
1. Clean the surface: Clean the floor and the underside of the KALLAX unit to ensure the adhesive sticks well.
2. Choose the pads: Use rubber or silicone pads that are at least 3-4 mm (0.12-0.16 inches) thick for stability.
3. Number and position: Use at least four pads, one at each corner. If the shelving unit is very tall or heavily loaded, it’s best to add extra pads in the middle under the shelves.
4. Attachment: Press the adhesive firmly, and ideally let it set for several hours without any load.
Additionally: Use wall anchors for safety, especially if there are children in the household.
Common mistakes: Sticking pads on dusty surfaces = poor adhesion.
Choosing pads that are too small = no effect.
Feel free to ask if you have any questions!
Wyatt
18 Jan 2020 08:02
keplo schrieb:
Are there any recommendations for anti-slip pads that are especially durable? For example, supporting 20-30 kg per corner?
In theory, a sufficiently large contact area combined with good material quality is enough. For 20-30 kg per corner, I recommend pads made of thermoplastic elastomer (TPE) or natural rubber, as these offer very high friction coefficients and compressive strength.
Important: The adhesives on the pads must also have strong bonding. Professional furniture feet often use hot melt adhesives or special acrylic adhesives that remain firmly attached even after years.
An alternative, if you are handy, is to use layered pads made of felt plus rubber or cork-rubber mixtures, customized to size and possibly fastened with screws.
One more tip: The higher the load, the more stable the base should be. On uneven floors, an anti-slip mat underneath is advisable because it adapts to the irregularities.
Regarding tipping risk, you cannot rely on pads alone. Combining them with solid wall anchoring is the best approach.
keplo
18 Jan 2020 08:30
Wyatt schrieb:
Regarding the risk of tipping, you can’t fully rely on pads alone.
This advice is very valuable! I initially had the shelf just standing loosely, but with the increasing weight, it will definitely become an issue.
I plan to use 4-5 mm (0.16-0.2 inch) thick anti-slip pads made of TPE and at the same time install a secure wall fixing.
Thanks also for the tips on the material and cleaning the surfaces before attaching – that sometimes seems to be a critical step that is easy to overlook.
Who has experience with combining anti-slip pads and metal brackets on the wall? Is it better to attach the brackets to the outside or inside of the shelf?
Ianlau
18 Jan 2020 09:05
keplo schrieb:
Who has experience with a combination of anti-slip pads and metal brackets on the wall?
This is how I did it: I fixed metal brackets inside, at the top on the back of the KALLAX, and to the wall. They are barely visible and hold extremely securely.
I attached the anti-slip pads to the bottom surfaces to stabilize the entire shelf and protect the floor. The brackets prevent tipping, while the pads reduce lateral sliding.
Make sure to secure the brackets to the wall using suitable anchors and screws according to the wall material. Use toggle bolts or heavy-duty anchors for drywall, and wall plugs for masonry walls.
