ᐅ My KALLAX shelf moves even with a light touch – any tips for preventing slipping?
Created on: 24 May 2015 10:03
Ganodan
I recently bought a KALLAX shelf unit from IKEA and am generally satisfied with it. However, I have noticed that the shelf tends to slide even with very light contact – even when it is empty or only partially loaded. Since it is standing on a smooth laminate floor, I suspect that the low friction is the main cause.
My question to you is: What effective anti-slip solutions do you know that can reliably stabilize the KALLAX shelf without affecting its appearance or functionality? Ideally, it should be something that is easy to apply and can be removed later without leaving any residue. Maybe someone has practical experience with rubber pads, felt pads, or other methods.
I look forward to your tips and advice!
Genuan
24 May 2015 15:03
What also helps are anti-slip mats designed for outdoor use. You can simply cut them to the right size and place them underneath, which works well with laminate flooring.
pauPierce
25 May 2015 09:27
First of all: To effectively solve the problem of the shifting KALLAX shelf, both static and dynamic forces acting on the furniture need to be considered.
A KALLAX shelf is usually quite light, especially when not heavily loaded, and it stands on a relatively smooth surface such as laminate flooring. This means the coefficient of friction is low, so even small horizontal forces can cause it to move.
From a technical perspective, the following measures are most effective:
1. Attach non-slip pads with a high rubber content under all four corners. This increases the friction at the contact surface. Make sure the pads are not only wide but also round or square with continuous contact to provide an optimal surface area.
2. Possibly add reinforcing crossbars or even secure the shelf to the wall. This is the safest way to prevent lateral movement and tipping.
3. Adjust the load distribution by placing heavy items on the bottom shelves, which helps stabilize the unit.
If it helps: Many users make use of standard rubber tray mats, which are usually more affordable when cut to size and offer very good grip. It is especially important that the surface is clean and free of grease before installing any of these measures.
I would like to know how heavily your shelf is currently loaded and whether you have already tried securing it to the wall?
dusujan
25 May 2015 10:54
pauPierce schrieb:
I would like to know how heavily your shelf is currently loaded and whether you have already tried fixing it to the wall?
I also think this is important, because depending on how the load is distributed, it can greatly affect stability.
In my case, it helped to fill the lower shelves with heavy items while placing rubber pads underneath.
Don’t be afraid of attaching it to the wall; this is usually quick to do and provides a lot of safety, especially if you have small children or pets.
Ganodan
25 May 2015 11:15
pauPierce schrieb:
I would like to know how heavily loaded your shelf currently is and whether you have already tried securing it to the wall?
Thank you for asking! At the moment, the shelf is moderately loaded, about 50% full, mainly with books and decorations. Due to the shallow depth of the KALLAX, the weight distribution is not ideal; the mass probably shifts forward.
I have not yet secured it to the wall, but I will definitely consider doing so, even though the shelf is supposed to be relatively stable on its own.
I will try your suggestions with the rubber pads and anti-slip mats and get back to you. Thanks for the helpful advice.
O
ONCARTER
26 May 2015 08:49
Ganodan schrieb:
I haven’t implemented wall mounting yet, but I will definitely consider it
You should definitely do that, especially if the shelf shifts even with slight contact. Besides safety, wall mounting also prevents damage to the shelf and surrounding items.
In addition to anti-slip pads, the included securing brackets are highly recommended. They are often inconspicuous but significantly increase overall stability.
I personally recommend thoroughly cleaning and degreasing the surface before applying the anti-slip pads. A clean surface ensures the adhesive strips hold as firmly as possible.
