ᐅ Are there specific door stoppers designed for KALLAX available at hardware stores?
Created on: 6 Aug 2024 09:32
SansanHello everyone,
I have a specific question about door stoppers in relation to the IKEA KALLAX shelving unit: Are there any door stoppers available at hardware stores that are specifically designed for the KALLAX unit? I am looking for products that are actually tailored to the dimensions and components of the KALLAX, for example, to prevent damage to the doors or to help stabilize the shelving unit.
Maybe someone has experience with this or knows manufacturers offering such specialized door stoppers? Thank you in advance!
Hello Sansan,
As far as I know, traditional hardware stores do not offer door stoppers specifically designed for the IKEA KALLAX. Standard door stoppers are usually made to be universal and are not tailored to specific furniture models.
I recommend looking for such products at specialized furniture accessory shops or directly through IKEA. They offer accessories compatible with KALLAX, even if these are not explicitly called "door stoppers," but rather door bumpers or cabinet locks.
If you want to try something from a hardware store, I would suggest choosing door stoppers with rounded edges and enough flexibility to avoid damaging the surface.
In addition to what Joshbe mentioned, it's important to consider the function of the door stopper. Many door stoppers available at hardware stores are designed for standard doors, not for furniture flap or sliding doors, such as those used with KALLAX units.
If the goal is to avoid damaging the door or furniture, self-adhesive door bumpers made of silicone or felt are often a better choice. These are versatile and protect both the door and the furniture.
So far, I haven’t seen KALLAX-specific door stoppers in hardware stores, mainly generic alternatives.
Nathanaelk6 Aug 2024 10:44Hello Sansan,
to answer your question in more detail: The construction of the KALLAX requires a special adjustment for door stoppers, as the doors usually rely on hinges that do not always need the classic door stop at certain contact points.
You won’t find specialized door stoppers at hardware stores that are specifically designed for this shelf size or hinge mechanism. The problem is that many door stoppers are intended for floor or wall mounting and not for furniture frames.
A practical approach would be to use universal door bumpers that can be attached by adhesive to the relevant furniture parts. Some users opt for silicone bumpers to prevent impacts when closing the doors.
However, I wonder: What type of door exactly do you want to fix or stop with this? Is it cabinet doors on the KALLAX, or room doors that hit the KALLAX? This could significantly influence the answer.
Nathanaelk schrieb:
What type of door do you want to fix or stop exactly? Are you referring to cabinet doors on the KALLAX or room doors that open against the KALLAX?Good question, thanks for pointing that out! Specifically, I mean the small doors that can be attached to the KALLAX, so the furniture doors, not room doors that hit it. I want to prevent the doors from being slammed too hard to avoid damage or noise.
The shelf is located in a passageway, and the doors are frequently opened and closed. Therefore, I am looking for a solution that can be discreetly integrated and is precisely suited for these furniture doors.
Based on your input, it can be said that there are no door stoppers officially offered by hardware stores that are specifically designed for KALLAX furniture doors.
Users typically rely on common door buffers that they customize themselves, such as those made of rubber or silicone, which are attached to the inside of the door or the inside of the shelf.
These are usually self-adhesive, do not leave residue, are affordable, and prevent the door from slamming shut too hard.
Alternatively, the use of soft-close hinges is recommended, which allow for gentler closing. However, these are usually separate furniture accessories and are not directly available for KALLAX at hardware stores but rather from specialized furniture accessory retailers.
