ᐅ My KALLAX rotates when I sit in the room – how can I secure it?
Created on: 5 Jan 2023 08:43
bob47
I have a large IKEA KALLAX shelving unit in my living room that I use as a seating area when friends visit. The problem is that the KALLAX shifts or rotates slightly on the floor whenever someone sits on it. This makes sitting on it a bit unstable and, above all, annoying because it doesn’t stay securely in place.
I have already tried using non-slip pads underneath, but that only helped a little. Are there any ways to secure the shelving unit so that it no longer rotates or moves, but can still be moved relatively easily later on?
Maybe someone knows a good solution or trick, materials, or suitable fasteners that I can use effectively. I would appreciate tips that are not just temporary fixes but actually stabilize the unit without damaging my wall. Thanks in advance!
anfeteo
5 Jan 2023 12:01
Hello bob47,
I want to approach the topic more systematically so you have all the options on the table.
1. Identify the causes:
- Rotation usually occurs due to uneven flooring or lack of support against the wall.
- The KALLAX has no base edges to stand securely on.
2. Solutions:
- Non-slip pads made of rubber or silicone under the furniture feet.
- Furniture brackets on the back, either screw-mounted or adhesive, depending on the wall type.
- Connect with carpet tape for extra grip.
- Place weight in the lower compartment to better stabilize the base.
3. Common mistakes:
- Using pads on uneven areas.
- Providing too little contact surface.
My advice: Use a combination of non-slip pads and furniture corner clamps. This provides stability without drilling while keeping the shelf movable.
Hope this helps!
nonpra
5 Jan 2023 12:29
For a quick solution, it is often enough to place a non-slip mat under each shelf leg. This allows the shelf to grip well while still being movable if necessary.
bob47
6 Jan 2023 07:55
Thank you for the detailed tips!
I have a question for better understanding: When I want to install the corner braces on the wall, I’m concerned that I might damage the wall. Are there special corner braces or fasteners that can be removed without leaving any residue or holes? Or is it true that adhesive strips generally aren’t suitable due to the load?
I’d appreciate any advice on how to stabilize the furniture in the most wall-friendly way possible.
INGRID34
6 Jan 2023 08:19
There are furniture adhesive kits that can be removed without leaving residue—usually made of silicone or special adhesives. However, the load capacity often depends on weight and usage. For a large shelf like KALLAX, I would recommend drilling instead, as adhesives typically do not hold well enough.
KUDAISY
6 Jan 2023 09:02
INGRID34 schrieb:
There are adhesive furniture sets that can be removed without leaving residues
These are indeed an option for lightly used furniture, but the KALLAX is quite stressed when used for sitting.
bob47 schrieb:
how to stabilize it in a way that is as wall-friendly as possible
My tip: First try easily removable brackets with drywall screws (which can be easily filled and smoothed) or clamp mounts (which don’t require drilling). Alternatively, there are special wall mounts for shelving that need only a few small holes.
For temporary fixing: anti-slip mats plus heavy weights in the lower compartments work great.
TEOZAR
6 Jan 2023 09:40
Regarding mounting without damaging the wall:
I have tried using transparent furniture tape, and if the shelf is not heavily loaded, it works well. However, there is a risk that it may tear under high load.
If you want to securely fix the shelf, the only reliable solution is wall mounting using screws that can be repaired later (by filling and painting). This is the standard approach for safety reasons.
If you want to be on the safe side, I would recommend doing it this way, as an unstable piece of furniture can be a real safety hazard.
