ᐅ My KALLAX rotates when I sit in the room – how can I secure it?
Created on: 5 Jan 2023 08:43
bob47
I have a large IKEA KALLAX shelving unit in my living room that I use as a seating area when friends visit. The problem is that the KALLAX shifts or rotates slightly on the floor whenever someone sits on it. This makes sitting on it a bit unstable and, above all, annoying because it doesn’t stay securely in place.
I have already tried using non-slip pads underneath, but that only helped a little. Are there any ways to secure the shelving unit so that it no longer rotates or moves, but can still be moved relatively easily later on?
Maybe someone knows a good solution or trick, materials, or suitable fasteners that I can use effectively. I would appreciate tips that are not just temporary fixes but actually stabilize the unit without damaging my wall. Thanks in advance!
brianna
7 Jan 2023 08:12
I think any solution is better than constantly worrying that the shelf might tip over or shift.
Maybe you could start by attaching small, discreet brackets to the back using removable screws. If the appearance bothers you, you can always paint over them later or cover them with decorations.
The most important thing is that you feel comfortable while sitting and don’t have to worry about the shelf moving. Safety comes first. 🙂
bob47
7 Jan 2023 08:53
Thanks to everyone for the helpful answers!
I will start by trying anti-slip pads and adding extra weight. If that’s not enough, I’ll look for small furniture brackets that I can install as unobtrusively as possible, placing them behind the shelf.
The suggestion to use gliders and rubber stopper pads also sounds good – they seem very neutral and flexible. I will definitely give that a try.
Once I have more experience, I’ll get back to share what worked best for me!
