ᐅ Finishing Cut Edges on BILLY Shelves – Tools and Techniques
Created on: 16 Mar 2016 08:23
JerryzarHello everyone,
I’m planning to assemble a Billy shelf unit from IKEA, and as with many flat-pack furniture items, the cut edges – meaning the edges of the boards that you might need to trim yourself or the factory edges – can sometimes appear a bit rough or uneven. I would like to properly finish these cut edges so they not only look better but are also more durable and resistant over time.
I’m wondering which tools are best for this: Should I use sandpaper, beginner-friendly edge trimming kits, or are there special edging tapes that can be used to seal such cut edges? It would also be great if you could share tips on the exact procedure – how many sanding passes are ideal, and in what order should the steps be done?
I’d appreciate practical advice and suggestions that also suit people who are not professional furniture builders. Thanks in advance!
Hello Jerryzar,
your question is really good and very practical. When refinishing the cut edges on the BILLY shelf, I actually recommend a multi-step approach.
First: light sanding with fine sandpaper (grit 120 to 180) – this effectively removes small imperfections and smooths the surface a bit. After that, you can seal the edges with edge banding or an edge tape, especially if the edges are not already factory-coated. These tapes are available at hardware stores and can be applied with an iron.
Regarding tools: a small file or sanding block can help work the edges more precisely, especially when sanding corners and edges. If you have a router with a suitable edge-trimming bit, that would of course be ideal to create a very clean and rounded edge right away.
Finally – and this is often underestimated – applying a protective layer of wood lacquer or wax is not a bad idea, as it increases durability and improves the appearance.
If you have any more questions, just ask! 🙂
I want to explain this in a bit more detail because I believe the topic deserves more attention.
BILLY shelves usually have a melamine-coated surface. However, the cut edges are often only finished with a thin edge band, which sometimes needs further treatment to prevent chipping. Generally, I recommend the following steps:
1. First, carefully inspect the cut edge. Are there any major splinters? If yes, gently smooth them with coarse sandpaper (80 grit), but be careful not to remove too much material to avoid damaging the stable core board.
2. Then, use finer sandpaper (180 to 240 grit) to smooth the surface and blend the transition to the coated carcass.
3. If the edge is exposed (i.e., particle board is visible), applying an edge band (also called edging tape) is advisable. It is applied using an iron and a damp cloth. Important: Trim the tape precisely beforehand so it fits flush with the shelf.
4. For final protection and a clean finish, I recommend treating the edges with clear varnish or hard wax after applying the edge band.
5. For someone experienced with a router, rounding the edges with a rounding router bit can look very elegant and professional, but this requires considerable skill.
One more question for you: Have you already cut the shelf, or do you want to work on the original cut edges afterward? This also affects the approach since freshly cut particle board edges are more delicate.
I hope this helps. If you need more details, feel free to ask.
bareynaldo16 Mar 2016 10:45benonon schrieb:
For someone experienced with router work, adding a small rounding to the edges using a rounding router bit can look very elegant and professionalThat’s exactly the point I find interesting: Why is it so often recommended to enhance these shelves visually? The BILLY is known as an affordable, functional piece of furniture, so a fancy rounding simply isn’t necessary. In my opinion, many people overestimate this “cosmetic edge upgrade.” A bit of sanding is more than enough; it’s not meant to become a designer shelf.
On the other hand – and I really mean this without sarcasm – using a router like that can certainly make a statement if you have the time and inclination. But in the end, it’s purely for fun.
Yay! I can relate when it comes to sanding and touch-ups!
What I’d also recommend is using edge rollers or rubber rollers when applying edge banding. This ensures a really firm press and prevents air bubbles. Unfortunately, you often see bubbles when the edge banding is just pressed on quickly and not rolled over again.
And hey, don’t be afraid of the tricky part: when applying edge banding with an iron, always place a cloth in between! Otherwise, the glue sticks to the iron’s soleplate.
Very important: after applying, you can carefully trim any excess with a sharp utility knife or a special edge trimmer.
Good luck, it’s going to turn out great! 🙂
