ᐅ Is it possible to mount an Ikea Besta shelving unit securely to the wall?
Created on: 7 Dec 2011 11:46
santesana
santesana
7 Dec 2011 11:46
Hello!
For aesthetic reasons, I would like to wall-mount a Besta shelf measuring 60cm x 40cm x 192cm (24 inches x 16 inches x 75 inches). Does anyone know if this is possible and what needs to be considered?
Thank you!
IKEA-Profi
7 Dec 2011 18:44
Hello!
For aesthetic reasons, I would like to wall-mount a Besta shelf measuring 60 x 40 x 192 cm (24 x 16 x 76 inches). Does anyone know if this is possible or what needs to be considered?
Thank you!
In my opinion, this is not possible because the shelf is not designed for that. I think the fasteners will simply pull out of the shelf due to the weight.
bergpriv
8 Dec 2011 01:05
Hello
Basically, yes, with the brackets (they are free with spare parts – at least in Austria) of the kitchen cabinets you can screw everything to the wall. I did this with Besta years ago, and it is still holding.
Best regards, bergpriv
IKEA-Profi
8 Dec 2011 07:38
It can work out well, but it doesn't have to.
IKEA-Experte
8 Dec 2011 10:39
Whether it will hold well or not mainly depends on how heavy the shelf will be loaded and whether appropriate anchors and screws are used. For heavier loads, I would recommend using more than two brackets. In general, definitely avoid using the included wall fasteners, as they are only meant as safety devices.
Nayla_1068
11 Dec 2011 23:58
It won’t hold long-term because the shelf has a corrugated cardboard core, like those in lacquered or Expedit shelves. Where exactly is the bracket supposed to hold, or even just support the weight of the shelf itself?
If it absolutely must be attached to the wall, then build some kind of support structure UNDER the shelf and place it on that. This way, the wall brackets will only provide the usual anti-tilt function. There was already quite a heated discussion here about Besta and wall mounting. So it’s better to avoid it.
NfU
Na.
