ᐅ Kallax damaged by cleaning products – how to restore?
Created on: 3 Dec 2015 10:03
Heleneix58
Heleneix58
3 Dec 2015 10:03
Hello everyone, I have a problem with my Kallax shelving unit from Ikea. Unfortunately, I made a mistake while cleaning: I probably used an unsuitable cleaning agent, most likely one that was too harsh and/or not suitable for wood veneers. Now there are several dull discolorations and some areas where the surface feels slightly roughened. I’m not sure if it’s just surface damage or if the material has been penetrated. My question is: How can I best restore a Kallax shelving unit that has been damaged this way by using the wrong cleaning products? Are there any recommended repair or restoration methods to visually improve or completely fix the surface? What approach has worked well for you when laminate or coated surfaces have been dulled or affected? I’m hoping for detailed tips—thanks in advance!
nikian
3 Dec 2015 10:18
Hello Heleneix58,
your description sounds like typical damage caused by aggressive cleaners that can soften or dissolve the protective varnish or laminate coating. In such cases, simply cleaning again usually won’t help.
The first step is to clean the shelf thoroughly—be sure to use mild dish soap or plain water—to remove any residue from the harmful substance. If the surface feels rough, very fine sandpaper (grit 400-600) can help gently sand the affected areas. Be careful not to press too hard to avoid further damage.
Afterwards, you can apply a thin layer of specialized furniture or laminate repair wax or a suitable touch-up marker to the surface. If you can’t find a touch-up marker, there are also liquid plastic repair kits available at hardware stores.
If the shelf is valuable, it’s also worth using special furniture care products, which should be chosen depending on the coating (for example, melamine care products for melamine resin coatings).
If possible, please send a more detailed description of the damaged areas or specify the material of the surface.
barEsperan
3 Dec 2015 10:22
It is best to gently sand again with very fine sandpaper, then use a suitable furniture touch-up marker. Important: do not use harsh cleaners anymore.
Heleneix58
3 Dec 2015 10:47
Thank you for the advice! The surface is indeed coated; if I'm not mistaken, it is melamine resin-coated particleboard. The matte discoloration looks streaky and feels somewhat rough.
My concern is that sanding might expose the white surface beneath or that I might sand unevenly. How fine should the sandpaper be exactly? And which products would you specifically recommend for application? Are there products that are particularly suitable for melamine resin, or do I need to use a special laminate varnish?
nikian
3 Dec 2015 10:52
barEsperan schrieb:
Lightly sand again with very fine sandpaper
Exactly, Heleneix58, it’s really just about very gentle sanding to slightly roughen up the dull, damaged surface and prepare it for the touch-up pen. Sandpaper with a grit of 600 is ideal. Lower grits (e.g., 400) are a bit coarser and might leave visible scratch marks if you’re not careful.
Heleneix58 schrieb:
Which products do you specifically recommend for application?
For melamine, special repair kits for laminate or plastic are best. For example, you can find products at hardware stores or online from brands like "Borma Wax" or "Dr. Schutz Laminate Repair Kit." These contain colored waxes or paints that you can apply with a small spatula or brush. You can choose shades that closely match your surface.
If you only have small spots, a clear furniture polish pen or color-matched touch-up pen from crafts stores, e.g., for plastic model making, can also help. I definitely recommend testing first on an inconspicuous area.
fodeo
3 Dec 2015 11:05
I had a similar problem. For me, lightly sanding the area with 600-grit sandpaper and then applying furniture care oil helped. This often restores the shine.
