ᐅ KALLAX dusty after renovation – how to clean?
Created on: 20 Feb 2021 09:13
evadi
evadi
20 Feb 2021 09:13
I recently renovated my apartment, including fresh paintwork and some dust on the floor. During this, my IKEA KALLAX shelf unfortunately became quite dusty, and the fine renovation dust seems almost embedded on the surfaces. I want to clean the shelf carefully without damaging the surface or encouraging dust to stick again later.
My question is: What is the best method to clean a KALLAX shelf after renovation work so that fine dust is effectively removed without harming the surface? Are there any specific cleaning agents, procedures, or tools you would recommend? I am also interested in tips on how to prevent dust buildup on smooth surfaces in the future.
Thanks in advance for your help!
giabau
20 Feb 2021 09:34
evadi schrieb:
What is the best method to clean a KALLAX shelving unit after renovation work to effectively remove fine dust without damaging the surface? Are there any specific cleaning agents, procedures, or tools you would recommend?
Hello evadi,
You’ve phrased the question very precisely—that’s really helpful. Here is a structured approach that has proven effective for multiple KALLAX cleanings:
1. Dry cleaning: Start by roughly removing large amounts of dust with a microfiber cloth (dry or only lightly dampened). Important: avoid using a coarse rag or a brush with stiff bristles, as that tends to just spread the dust around.
2. Gentle damp cleaning: A microfiber cloth slightly moistened with clear, lukewarm water is usually sufficient. Avoid harsh cleaning agents, since KALLAX is typically coated with a melamine finish, which is sensitive to aggressive substances.
3. Alternative solution: For stubborn dust or light stains, use diluted vinegar (1 part vinegar to 10 parts water). Vinegar gently dusts and cleans without being too aggressive.
4. Drying: After wiping, always buff with a dry, lint-free cloth to prevent water spots.
5. Regular dust prevention: If you recently had fresh paint applied, it’s worth cleaning more often since dust tends to stick more easily. Using a humidifier in dry rooms can also help reduce dust buildup.
Tip: Avoid sponges with abrasive sides or strong chemicals, as these can quickly damage the surface.
If you’d like, I can also provide examples of gentle cleaning products. Just let me know.
WARREN
20 Feb 2021 09:56
evadi schrieb:
What is the best way to clean a KALLAX shelf after renovation work to effectively remove fine dust without damaging the surface?
First, go over it with a dry microfiber cloth, then wipe it with a damp cloth using water. Avoid using strong cleaning agents.
Blavin
20 Feb 2021 10:15
To avoid damaging the surface of the KALLAX, do not use cleaning products containing solvents or aggressive cleaners. The melamine surface is sensitive to alcohol, acetone, or abrasive agents. Therefore, I recommend:
- First, remove dry dust with a slightly damp microfiber cloth.
- Use mild soapy water (e.g., a pH-neutral dishwashing detergent solution).
- Use only a small amount of water and dry quickly with a dry cloth.
This reduces the risk of water spots or surface damage. After renovations, a small vacuum cleaner with a soft attachment can also help remove coarse dust before wet cleaning.
evadi
20 Feb 2021 10:42
giabau schrieb:
Use diluted vinegar (1 part vinegar to 10 parts water). Vinegar gently removes dust and cleans without being too harsh.
Interesting tip about vinegar! I was worried that vinegar’s acidic pH might damage the surface. Do you have any experience with its effects on melamine? I don’t want to risk the surface becoming dull or damaged.
Blavin schrieb:
First remove dry dust with a slightly damp microfiber cloth.
Sounds reasonable, I’ll proceed carefully and start by dusting dry. Thanks to you all!
giabau
20 Feb 2021 11:10
evadi schrieb:
I was concerned that vinegar, due to its acidic pH, might damage the surface.
That’s understandable. I use vinegar diluted at most 1:10 and only sparingly. Undiluted vinegar can indeed damage the finish on melamine surfaces, so dilution is key.
Test it first on an inconspicuous spot to be sure. For many, a mild dish soap in warm water is perfectly sufficient.
Don’t worry— with the right dilution and careful wiping, the risk is very low.
Here’s a quick tip: if possible, avoid soaking the surface and instead “wipe” it with a lightly misted cloth. This minimizes the contact time of the liquid.
