ᐅ Does anyone use antistatic sprays for the KALLAX shelving unit?
Created on: 12 Jun 2024 08:37
Jami6
Jami6
12 Jun 2024 08:37
I recently bought a KALLAX shelf from IKEA and am wondering if any of you have experience with antistatic sprays on this material. Specifically, I am interested in whether such sprays actually help reduce dust on the surfaces without damaging the plastic or the finish.
If so, which product would you recommend, and how often should the spray ideally be applied? It would also be important for me to know if there are any special considerations – such as drying times, specific cleaning before application, or possible unwanted side effects on the material.
I would greatly appreciate your practical experiences and tips. Thank you in advance!
bauku
12 Jun 2024 09:04
Hey Jami6, it’s great that you brought up this topic! 🙂
I’ve been using antistatic spray on my KALLAX for a while now and can only share positive feedback. It mainly helps to significantly reduce the annoying dust attraction effect! The key is to clean the shelf thoroughly beforehand—preferably with a slightly damp cloth—to avoid trapping dirt particles in the spray.
I spray it on about every 2 weeks and let it dry properly. Since then, I’ve noticed much less dust on the surfaces. Which spray exactly? I usually use ESD-safe products from the electronics sector—they’re gentle on plastics.
GiRoyce
12 Jun 2024 09:45
Hello Jami6,
I can gladly add some basic information here: Antistatic sprays are mainly used to prevent electrostatic charges on surfaces, which in turn reduces the attraction of dust particles. For KALLAX, whose surfaces are mostly made of painted particleboard or melamine, this is generally safe.
However, it is important that the spray is suitable for use on plastic. Also, the room should be well ventilated, as many sprays contain volatile organic compounds. Application: clean the surface first, then apply the spray thinly, allow it to air out, and only then proceed with further treatments or use.
I recommend testing first on an inconspicuous spot to ensure that the finish is not damaged.
Nathanaelk
12 Jun 2024 10:18
Hello Jami6,
I can provide some more technical details on this topic. Antistatic sprays usually work through special ingredients that increase the electrical conductivity of the surface, preventing static charges from building up. When applying them to KALLAX shelves, it’s important to consider that the surface is melamine-coated, and the effectiveness depends on the underlying material.
Very important: a thorough cleaning before application is essential, preferably using a microfiber cloth and some isopropanol to ensure no residues interfere. After that, spray sparingly from about 20-30 cm (8-12 inches) away, so it doesn’t accumulate in droplets on the shelf.
One more tip: some sprays can become slightly sticky over time or when exposed to UV light, which can attract dust. Therefore, always test on a small hidden area first!
Which brand are you using or have you considered so far?
Jami6
12 Jun 2024 10:47
Nathanaelk schrieb:
Which brand exactly are you using, or have you already considered something?
Thank you for the explanation; that really helps! To be honest, I haven’t yet settled on a specific manufacturer. I’ve looked at discount sprays for electrical appliances, but I’m unsure if they are suitable for wood or melamine surfaces.
Does anyone have recommendations for reliable brands or specific products that are truly safe for KALLAX? It’s important to me that they do not contain any adhesive residues or staining substances.
te-min
12 Jun 2024 11:16
I can recommend the "3M antistatic spray." I use it myself on plastic and painted wood. It leaves no residue and works well.
