A few days ago, I had a dye accident with a fabric on my IKEA Kallax shelf. Some of the white surfaces became stained, probably due to dye residues that leaked during the process. My question is whether and how these stains can be effectively cleaned from the Kallax without damaging or discoloring the surfaces.
The shelf is made of a coated fiberboard, right? I’d prefer not to use harsh cleaners that could ruin the furniture. Do you have any tips or experience on how to remove dye or fabric dye stains from such a surface?
Thanks in advance for your help!
Hello zaiddi,
The Kallax is actually made of a melamine resin-coated fiberboard. This material is generally quite durable, but stronger cleaning agents can leave the surface dull or stained.
For fresh paint stains, I recommend first trying a mild cleaner, such as soapy water. If that doesn’t work, you can carefully use isopropyl alcohol, which sometimes dissolves paint particles effectively. It is important to avoid rubbing too hard or abruptly to prevent scratches.
In any case, I would test on an inconspicuous area before using any cleaner on a larger surface.
In summary: The surface coating of the Kallax is resistant to moisture and many common household cleaners. However, solvents such as acetone can damage the surface and cause it to become dull.
Therefore, I recommend a step-by-step cleaning approach: start with mild agents like soapy water, then use isopropanol if necessary. For stubborn paint stains that do not improve quickly, I would advise against using solvents and suggest considering professional cleaners instead.
Hello zaiddi,
I can understand that this is frustrating. Paint on surfaces like those of the Kallax is not easily removed. If mild cleaners and isopropanol don’t work, you can try gently using an eraser – sometimes it lifts such stains.
It’s important to proceed step by step and let the area dry in between so you can properly assess the cleaning effect.
Also, if the shelf has a loose protective film, carefully peeling it off might already remove some of the residue, if there is a protective layer applied.
