ᐅ Proper Care for Ikea METOD Countertops and How to Avoid Scratches
Created on: 29 Jun 2024 18:23
Memando
Memando
29 Jun 2024 18:23
I recently installed an Ikea METOD kitchen with the matching countertops and, of course, I want to keep them looking like new for as long as possible. However, I’m wondering how to properly care for the countertops so that their color and surface don’t deteriorate. I’m also interested in how to effectively avoid scratches, especially when cooking daily and frequently handling knives or pots.
I’ve read that you should avoid harsh cleaning agents, but I’m uncertain which products or household remedies are actually gentle on the surface. Are there any special tips or care instructions that Ikea itself recommends?
Maybe someone has practical experience with METOD countertops or can share how to handle them properly, so I can enjoy them for a long time? Thanks in advance!
BARSAN
29 Jun 2024 19:11
For the care of Ikea METOD countertops, I recommend:
- Avoid using abrasive cleaners or harsh chemicals.
- Usually, a damp cloth with mild dish soap is sufficient.
- To prevent scratches, it’s best to use cutting boards.
- Do not place hot pots directly on the countertop.
These simple guidelines help preserve the surface.
Domau0
30 Jun 2024 08:47
[@Memando, post: c4n9z4, member: XXX]
"I recently installed an Ikea METOD kitchen with the matching countertops and, of course, I want to keep them looking like new for as long as possible. However, I’m wondering how to properly care for the countertops to prevent fading or surface damage. I’m also interested in how to effectively avoid scratches on the surfaces, especially when cooking daily and frequently using knives or pots."
Care instructions for Ikea METOD countertops vary depending on the material type—whether laminate, wood, or quartz composite. In general:
- Laminate countertops: These are fairly durable but sensitive to heat and sharp objects. Avoid abrasive cleaners or solvents. Cleaning with a damp cloth and mild detergent is sufficient. Grease stains can be gently removed with dishwashing liquid.
- Wood options (solid wood or veneer): Regular treatment with special wood oil is recommended to protect the surface and prevent drying out. Avoid standing moisture, as it can cause swelling.
- Quartz or composite countertops: Very resistant, but you should still avoid aggressive cleaning agents. Scratches are difficult to remove, so always use a cutting board.
Regarding scratches: Always use cutting boards—never cut directly on the countertop. Also, avoid placing hot pans directly on the surface, as heat can cause damage.
Tip: IKEA usually provides care instructions that you should follow carefully, since failure to do so may void the warranty.
If you want, you can tell me the exact countertop type, and I can offer more specific advice.
Summary:
- Follow care based on material type
- Avoid harsh or abrasive cleaners
- Use cutting boards
- Do not place hot items directly on the surface
- Oil wooden countertops regularly
Hope this helps you!
lyndon
1 Jul 2024 12:36
[quote=Domau0, post: l2x1h0, member: XXX]
"Regarding scratches: Always use cutting boards, never cut directly on the countertop. Also, hot pans should not be placed directly on the surface, as heat can damage it."
I agree with this. Additionally, I would like to point out that even with laminate surfaces, small micro-scratches can sometimes be unavoidable. To counter this, it is worth maintaining the surface with a protective wax or special laminate care products that create a light protective layer and make the surface somewhat more resistant.
Furthermore, you should avoid using strong chemical cleaners during cleaning because they can damage the surface texture and increase its sensitivity to scratches.
Personally, I apply a mild care wax several times a year to my METOD countertop and have noticed fewer visible signs of wear since then. This not only improves protection but also refreshes the color brilliance.
If you are interested in special care products, be sure to check that they are compatible with the countertop material – this is usually indicated on the packaging.
One final recommendation: For plastic or laminate countertops, always use microfiber cloths for cleaning, as they are especially gentle.
