ᐅ Correct Installation of Ikea Metod Baseboards with Underfloor Heating
Created on: 29 Oct 2021 18:22
Sotimon51
Sotimon51
29 Oct 2021 18:22
I am currently planning the installation of the Ikea Metod toe kicks in my new kitchen. A underfloor heating system has been installed there, so I want to be especially careful not to affect the heat output. My specific question is: How should the Ikea Metod toe kicks be installed with underfloor heating to ensure they are securely attached, prevent moisture or heat buildup, and avoid any damage to the heating system? Are there any special instructions or additional steps to consider, for example regarding seals, distances from the floor, or the method of fastening to the cabinet carcass?
I have already checked Ikea’s installation manual, but I couldn’t find any information about underfloor heating. Who has experience or expert knowledge on this?
Thanks in advance!
Leonardteo
29 Oct 2021 19:03
Basically, it is important that baseboards in a floor heating system are not completely airtight against the floor, as this can limit heat output. Ikea’s Metod baseboards are usually designed to be attached to the cabinet feet, leaving a small gap to the floor.
Also, installing them without applying too much pressure directly onto the floor helps maintain the efficiency of the floor heating. Additionally, I would recommend using sealing tapes or moisture-resistant materials at the edges, in case moisture around the baseboard area is a concern.
The fastening is typically done with Ikea clips that attach to the cabinet frames, allowing the baseboards to snap in precisely. This helps avoid a too-tight connection to the floor.
Tinaneo
29 Oct 2021 20:21
Leonardteo schrieb:
Basically, it is important that baseboards are not sealed airtight to the floor when underfloor heating is installed,
That’s true, but I would add that it’s not just about air circulation; it’s also about preventing heat buildup. Especially with Ikea Metod, the plastic can warp if exposed to continuous high heat.
Additionally, we should not only consider the installation but also protect the material from moisture, which can still occur even when the floor is dry. Therefore, I believe leaving a small gap between the floor and the baseboard is advisable. Those who don’t address this risk stress or later mold problems.
Does anyone have measurements or experience regarding temperature exposure directly at the baseboards? I think that would be useful for a solid installation guide.
rekijan
30 Oct 2021 07:04
Tinaneo schrieb:
I think that would be helpful for a detailed installation manual.
Absolutely right! I installed my Metod baseboards with underfloor heating and always leave a small gap from the floor, about 5 mm (0.2 inches). This allows the heat to circulate freely and prevents heat buildup in the plastic baseboards.
I also use the original Ikea fastening clips; they hold well and avoid unnecessary pressure. If you want, you can also place flexible, waterproof sealing strips at the base to prevent moisture from rising from below without blocking the heat.
This way, I am confident that everything fits properly and the heating works as intended.
neoren
30 Oct 2021 09:16
Always install baseboards with a gap.
Do not glue directly to the floor.
Use the original clips.
A gap of approximately 5 mm (0.2 inches) ensures heat dissipation.
Moisture protection with sealing cords is optional.
Sotimon51
30 Oct 2021 10:47
reKijan schrieb:
I installed my Metod baseboards over underfloor heating and always leave a small gap to the floor, about 5 mm (0.2 inches).
Thanks for the tip, 5 mm (0.2 inches) sounds reasonable. Does anyone have experience with how stable the baseboards are when installed with this small gap? I’m concerned that the material might loosen or break under higher stress (e.g., boots hitting the baseboard). Are certain fixing methods not suitable in this case, or do you have any tips on how to ensure the baseboards stay firmly attached?
