In about three weeks, we are supposed to finalize our electrical planning on site. Unfortunately, our electrician is somewhat old-fashioned, which makes it difficult for me to collaboratively plan a future-proof electrical setup with him. Therefore, I am currently educating myself to ensure that the networking in our single-family home is fundamentally future-proof.
Basically, it’s about the LAN network... LAN wall outlets are relatively expensive, so proper planning is even more important.
About us:
- Mid to late 20s – couple without children. Planning for 2 children in the near future.
- Single-family house with a usable basement, 2 full floors, and fully equipped with concrete ceilings
- Utility room in the basement with air-to-water heat pump, ventilation system, photovoltaic system
- The router is planned to be located in the office on the ground floor
- The upper floor includes bathroom / bedroom / 2 children’s rooms
- No satellite dish or cable TV — we will use Internet TV exclusively!
Now, I am struggling to network our single-family home sensibly but as cost-effectively as possible.
I have the following questions:
1. Slightly off-topic: In the living room, I would like to have an in-wall conduit installed on the TV wall (the TV will be wall-mounted) so that no cables are visible. Is this sensible and affordable? I will get exact prices from my electrician if this makes sense at all. Would it also make sense to install power outlets at TV height? How do you plan the connections on your media wall reasonably? What should be considered?
Since we plan to use a Magenta TV box and thus IP-TV, a total of four LAN ports in the living room area would presumably be useful, right?
2. How many LAN outlets and especially where should LAN outlets be installed? Mainly: which cable? Is CAT6 sufficient?
→ Such a double LAN outlet certainly costs close to €200, so planning must be really sensible.
Is it really necessary to install 2 double LAN outlets in each children’s room? I always wonder: what is actually going to be plugged in there?
One port for the TV and one port for a multimedia device should be enough, right? So four connections would probably be overkill, correct?
The fact is: It will certainly take years or decades before our children actually use these outlets... Who knows what changes might happen by then? Therefore, could we not cost-effectively use empty conduits (empty pipes) instead?
Is it also possible to “branch off” from an existing double outlet afterward to add more ports for the room? What should be considered here? Or should we consider having an empty conduit prepared in another spot in the room so that a socket can be installed later?
3. How do you solve the “router problem”? Should the one router be placed in the office (ground floor) with LAN outlets in the existing bedrooms upstairs to ensure a stable LAN connection? Or is a router upstairs absolutely necessary?
4. How important are LAN outlets in the utility room? Should the router possibly even be located in the utility room? Because of the concrete ceiling between basement and ground floor, a second router would almost certainly be needed. How should this situation be handled with a basement?
5. What do you think about installing empty conduits for CAT cables in the kitchen / hallway etc. to enable later retrofitting? Is this relatively affordable in new builds?
I would appreciate any feedback so we can make the best possible plans 🙂
About us:
If the basement's appearance is not very important, you can install a surface-mounted network outlet and connect it visibly to the access point with a patch cable. This is how it’s done in our office building since the access points were installed a few years later.
With some luck, the access point has a bit of space on the back where you can fit something. However, you need to get an original access point and test it. Even if it works now, a new access point in a few years might have less space there.
For me, the simplest solution is still to use a spacer ring between the ceiling and the access point to hide the cables. Of course, this means the access point won’t sit flush against the ceiling.
Otherwise, you can have a hole made in the concrete ceiling.
AllThumbs16 May 2022 08:20Core drilling would also be my recommendation. I had it done afterwards as well since I decided relatively late to install a KNX flush-mounted occupancy sensor there. It went smoothly without any issues.
Alternatively, you could try attaching a plug directly to the installation cable.
In one part of the house, I also solved it this way myself, but it was a wall with a cavity behind it, so I was able to push the installation cable back to the right length. It was tricky, but the access point is working and is mounted directly on the wall where the installation cable comes out.
Benutzer20016 May 2022 09:33fromthisplace schrieb:
The electrician only installed an empty conduit coming out of the ceiling there. I probably won't have any chance to get the installation cable and patch cable to the access point, right?With a UniFi Nano, that shouldn't be a problem at all. Just the patch cable — power via PoE.As long as the ceiling has not yet been poured and only the precast concrete slab is in place, all options are still available. Later on, it will require more effort, or alternatively Keystone jacks can be used on the installation cable, or even RJ-45 connectors directly.
Even higher quality patch cables with TM21/Hirose connectors are difficult to accommodate. The "in-field assembly connectors" are even larger and bulky. They don’t fit behind any access point. And you probably don’t want to use regular RJ45 connectors, especially when working with PoE, right?
