ᐅ Planning Electrical Systems for Future-Proofing
Created on: 2 Nov 2021 12:37
exto1791
In about three weeks, we are supposed to finalize our electrical planning on site. Unfortunately, our electrician is somewhat old-fashioned, which makes it difficult for me to collaboratively plan a future-proof electrical setup with him. Therefore, I am currently educating myself to ensure that the networking in our single-family home is fundamentally future-proof.
Basically, it’s about the LAN network... LAN wall outlets are relatively expensive, so proper planning is even more important.
About us:
- Mid to late 20s – couple without children. Planning for 2 children in the near future.
- Single-family house with a usable basement, 2 full floors, and fully equipped with concrete ceilings
- Utility room in the basement with air-to-water heat pump, ventilation system, photovoltaic system
- The router is planned to be located in the office on the ground floor
- The upper floor includes bathroom / bedroom / 2 children’s rooms
- No satellite dish or cable TV — we will use Internet TV exclusively!
Now, I am struggling to network our single-family home sensibly but as cost-effectively as possible.
I have the following questions:
1. Slightly off-topic: In the living room, I would like to have an in-wall conduit installed on the TV wall (the TV will be wall-mounted) so that no cables are visible. Is this sensible and affordable? I will get exact prices from my electrician if this makes sense at all. Would it also make sense to install power outlets at TV height? How do you plan the connections on your media wall reasonably? What should be considered?
Since we plan to use a Magenta TV box and thus IP-TV, a total of four LAN ports in the living room area would presumably be useful, right?
2. How many LAN outlets and especially where should LAN outlets be installed? Mainly: which cable? Is CAT6 sufficient?
→ Such a double LAN outlet certainly costs close to €200, so planning must be really sensible.
Is it really necessary to install 2 double LAN outlets in each children’s room? I always wonder: what is actually going to be plugged in there?
One port for the TV and one port for a multimedia device should be enough, right? So four connections would probably be overkill, correct?
The fact is: It will certainly take years or decades before our children actually use these outlets... Who knows what changes might happen by then? Therefore, could we not cost-effectively use empty conduits (empty pipes) instead?
Is it also possible to “branch off” from an existing double outlet afterward to add more ports for the room? What should be considered here? Or should we consider having an empty conduit prepared in another spot in the room so that a socket can be installed later?
3. How do you solve the “router problem”? Should the one router be placed in the office (ground floor) with LAN outlets in the existing bedrooms upstairs to ensure a stable LAN connection? Or is a router upstairs absolutely necessary?
4. How important are LAN outlets in the utility room? Should the router possibly even be located in the utility room? Because of the concrete ceiling between basement and ground floor, a second router would almost certainly be needed. How should this situation be handled with a basement?
5. What do you think about installing empty conduits for CAT cables in the kitchen / hallway etc. to enable later retrofitting? Is this relatively affordable in new builds?
I would appreciate any feedback so we can make the best possible plans 🙂
rick201823 Feb 2023 06:18
To use VLANs and similar features, you also need a UniFi router or Dream Machine... As I said, I would stay within that system.
Tassimat
23 Feb 2023 21:38
fromthisplace schrieb:
Do you see any other advantages compared to a switch from a different manufacturer?
You might want to take a closer look at the (idle) power consumption if you want to optimize operating costs.
X
xMisterDx
24 Feb 2023 14:24
Ongoing costs should not be underestimated.
100 watts continuous operation (which you reach quicker than you might think) amounts to 876 kWh over the course of a year. This is without end devices.
fromthisplace
7 Apr 2023 14:33
I’d like to speak up again. By now, our four U6 Pro units are mounted on the ceiling. I spent a bit more on the switch and chose the Ubiquiti 24 PoE. Once everything is finished, I’ll gladly write a final update. 🙂
Until then, I have a question:
Today, I noticed that Metz Connect 6a keystones are used for the installation cables. My clear intention was to use Cat 7 throughout. Cat 7 is installed everywhere else.
Are the 6a keystones acceptable, or should I have this corrected?
Fuchur
7 Apr 2023 20:49
You probably want RJ45 sockets, right? They are not available in Cat.7.
fromthisplace
7 Apr 2023 20:54
P.S.: The 6a keystones can
Fuchur schrieb:
You want RJ45 sockets, right? They are not available in Cat.7
Oh. I'll file that under: Better embarrassed here than with the electrician. 🙂
