ᐅ Planning Electrical Systems for Future-Proofing
Created on: 2 Nov 2021 12:37
exto1791
In about three weeks, we are supposed to finalize our electrical planning on site. Unfortunately, our electrician is somewhat old-fashioned, which makes it difficult for me to collaboratively plan a future-proof electrical setup with him. Therefore, I am currently educating myself to ensure that the networking in our single-family home is fundamentally future-proof.
Basically, it’s about the LAN network... LAN wall outlets are relatively expensive, so proper planning is even more important.
About us:
- Mid to late 20s – couple without children. Planning for 2 children in the near future.
- Single-family house with a usable basement, 2 full floors, and fully equipped with concrete ceilings
- Utility room in the basement with air-to-water heat pump, ventilation system, photovoltaic system
- The router is planned to be located in the office on the ground floor
- The upper floor includes bathroom / bedroom / 2 children’s rooms
- No satellite dish or cable TV — we will use Internet TV exclusively!
Now, I am struggling to network our single-family home sensibly but as cost-effectively as possible.
I have the following questions:
1. Slightly off-topic: In the living room, I would like to have an in-wall conduit installed on the TV wall (the TV will be wall-mounted) so that no cables are visible. Is this sensible and affordable? I will get exact prices from my electrician if this makes sense at all. Would it also make sense to install power outlets at TV height? How do you plan the connections on your media wall reasonably? What should be considered?
Since we plan to use a Magenta TV box and thus IP-TV, a total of four LAN ports in the living room area would presumably be useful, right?
2. How many LAN outlets and especially where should LAN outlets be installed? Mainly: which cable? Is CAT6 sufficient?
→ Such a double LAN outlet certainly costs close to €200, so planning must be really sensible.
Is it really necessary to install 2 double LAN outlets in each children’s room? I always wonder: what is actually going to be plugged in there?
One port for the TV and one port for a multimedia device should be enough, right? So four connections would probably be overkill, correct?
The fact is: It will certainly take years or decades before our children actually use these outlets... Who knows what changes might happen by then? Therefore, could we not cost-effectively use empty conduits (empty pipes) instead?
Is it also possible to “branch off” from an existing double outlet afterward to add more ports for the room? What should be considered here? Or should we consider having an empty conduit prepared in another spot in the room so that a socket can be installed later?
3. How do you solve the “router problem”? Should the one router be placed in the office (ground floor) with LAN outlets in the existing bedrooms upstairs to ensure a stable LAN connection? Or is a router upstairs absolutely necessary?
4. How important are LAN outlets in the utility room? Should the router possibly even be located in the utility room? Because of the concrete ceiling between basement and ground floor, a second router would almost certainly be needed. How should this situation be handled with a basement?
5. What do you think about installing empty conduits for CAT cables in the kitchen / hallway etc. to enable later retrofitting? Is this relatively affordable in new builds?
I would appreciate any feedback so we can make the best possible plans 🙂
hanse987
16 Jan 2022 15:16
Pumpernickel1 schrieb:
In the attic, we have a storage room where we have planned the network and power outlets. We will connect an access point there ourselves.
You will have good Wi-Fi in that storage room. How much reaches the rest of the house, where you really need Wi-Fi, remains to be seen.
Seeing what Elis delivers in the networking area, I understand why they are only allowed to install the LAN cables and do the equipotential bonding for me.
majuhenema
16 Jan 2022 16:16
Araknis schrieb:
They use Somfy, the most isolated standalone solution on the planet.
Okay, is that just unfortunate or a deal-breaker?
Araknis16 Jan 2022 18:19
It already works, but only with its own remote control or separate switches.
11ant16 Jan 2022 18:30
majuhenema schrieb:
Okay, is this just unfortunate or a major problem?
Proprietary solutions are generally problematic – even more so when they develop their own standards at every level: network topology, protocol, bus systems, connector types, and so on.
In the “best case,” the manufacturer merges with a competitor who follows a different approach, one of the two product lines is discontinued, and your house's system basically becomes electronic waste—unless you have an expert in soldering, networking, and programming on hand.
majuhenema
16 Jan 2022 18:43
Do you have a recommendation that offers a better solution and can be installed in the Lower Franconia region?
Araknis16 Jan 2022 19:03
One possible solution could be the Somfy flush-mounted transmitter. It is installed behind a standard switch, allowing you to stay within your current switch system. If you have Ideal Standard electrical fittings, this is a good option. However, if you are heading towards a smart home setup, you will still lack feedback from the drive.
